Leo Vince exhaust - need help
Old May 9, 2010 | 12:58 AM
Jens_denmark's Avatar
Jens_denmark is on a distinguished road
Exclamation Leo Vince exhaust - need help
Hi
So i bought em, looks damn nice.
The vtr run fine with the db killers in, np there.
But when i remove the db killers, the problems started. about 4.5-5k rpm it start to run "funny" like it aint getting enouch fule.
I took out one of the sparks plugs, and they look kind of white in the top.
So what do i need to do. raise the needel in carb ?. new main jets ?
Any suggestions ?
Jens.
Jens.
Old May 9, 2010 | 04:17 AM
residentg's Avatar
It is lean. Do you have a jet kit installed, do you know what jet sizes are in there? In any case, try raising the needled one clip (drop the clips on notch) to address your immediate problem, or put one washer under the oem needles if that is what you have. You can get them at RadioShack:
http://www.radioshack.com/product/in...ductId=2103391
Model: Flat Washers | Catalog #: 64-3022
Old May 9, 2010 | 08:24 AM
Problem solved :-P
Raised both needels a bit, the front got a new washer in, the rear have to washers in.
Front plug looks fine now :-P
The rear plug is still a bit white, maybe a new jet a bit higher or raise needel a bit more ?
Any suggestions ?
Jens
2whltuner
Jul 29, 2015 09:09 AM
bigmills
Dec 10, 2009 09:06 PM
salmanilla2000
Nov 20, 2009 05:29 PM
LEMINGMW
Mar 13, 2009 08:27 AM
Shmittay
Jan 25, 2006 08:37 AM
