R/R - Stator & battery diganosis.
Old Apr 24, 2011 | 10:53 AM
So I got my R/R swapped out with a mosfet one. (from a zx10)
And it works, I now at idle get 13.4V etc and it seems to behave just fine when a voltmeter is attached.
However I went on a test ride and I still got a flickering dash.
So is it just that my battery is toast (I expect it is) or should the R/R keep this from happening when the bike is running?
Or perhaps my stator is iffy?
Old Apr 24, 2011 | 11:00 AM
nykuryu's Avatar
nykuryu is on a distinguished road
did you completely drain your battery? if so it may be trashed.
Old Apr 24, 2011 | 11:09 AM
Oh I am sure the battery is trashed, it sat at ~9v for a long time.
I am just wondering if that alone is enough to cause the dash flicker while riding. (given a good R/R & stator)
Old Apr 24, 2011 | 11:18 AM
nykuryu's Avatar
i know that with my srad the gauges would die til i got to a high enough rpm (5K). turns out what i thought was a bad RR turned out to be a bad stator. its easy to check the stator. just ohm out the 3 phases and see if they are in spec. one of my phases were out by .1 ohms. put a new stator had no problems after that.
Old May 2, 2011 | 10:21 AM
Ok, it was just the battery.. Got that swapped and with the new R/R all is happy.
The old battery had two bulging cells LOL.. I really abused that thing.
Streaky
Jun 7, 2010 08:36 AM
Blueracer
Apr 21, 2010 05:06 AM
mcbrien
Jan 16, 2008 08:08 AM
Blurr
Apr 24, 2007 01:05 PM
