Quick water pump question
I did some research and my weep hole is weeping...pun intended. I read that when rebuilding these units you need to get the shaft and bearings pressed in to a precise measurement. Might sound dumb but can I dissemble the unit or take off the entire case and take it to honda shop? (Don't trust the local guy I go to)
Or do it yourself
Or send it to someone to do it for you
So seeing as I don't know what actually is causing the weepage. Do you suggest just taking the water pump assembly off or te entire case cover on that side and replacing the gasket there as we'll?
You need to take the engine cover off. The water pump impeller is pressed into the cover. Download the Superhawk manual here and take a look at what is involved before delving into it, or if you dont already have one and want an actual paperback manual, thedeatons is selling one for a decent price in the classifieds.
Just sold my manual. THANK YOU FOR THE PLUG THOUGH!!!!
Water pump seals are easy. Try it! I use sockets as a "press" and gently tap the new seals in using the back of the socket and a light hammer. Very satisfying to do it yourself
James
James
Can it be done successfully with hammer and craftsman socket set..absolutely.
Do many more people screw it up than get it right? Absolutely
Take the cover off, drop it off at a reputable shop, pick it up in a few hours If they don't do it on the spot) pay an hour or less in labor, go home and install the cover with a new gasket and be back riding in minutes.
