problem starting after gas tank removal
Old Apr 22, 2011 | 03:24 PM
mikayelstylee's Avatar
bird
mikayelstylee is on a distinguished road
Question problem starting after gas tank removal
I removed the gas tank to have it painted. I reinstalled everything as it was before the tank was removed. The bike started initially and bogged down after about 30 seconds. Now it's turning over but just not starting. It sounds like the petcock is off but the valve is open. I do not have a vacuum hose from the back of the petcock but I didn't before I removed the tank either. I have a suspicion the vacuum hose is to blame but I'm not certain since I've never had one and have never had this issue. Any thoughts?
Old Apr 22, 2011 | 03:53 PM
The vacuum hose needs to be connected to the back of the petcock not the bottom.
search for PVLIR on this forum, it is so common it has it's own acronym.
Old Apr 22, 2011 | 05:42 PM
RWhisen's Avatar
Former Superchicken Owner
Another victim of PVLIR
Old Apr 22, 2011 | 05:51 PM
fred's Avatar
Mid-level Member
fred
one more thing to double-check. the petcock on/off indication labels are ***-backwards in my opinion. to me, the petcock is open when the labeling implies that it is in the closed position and vise-versa.
i actually stopped closing it when i remove the tank, due to the hurt it would later put on my brain. if i leave it open and note that, then i don't have to worry about the Honda petcock riddle labels. and gas won't spill out when it is left open if the petcock is in good working order, since the system requires vacuum in order to pull gas.
Old Apr 22, 2011 | 07:26 PM
NooB's Avatar
I loves me twins
Old Apr 23, 2011 | 08:04 PM
bird
where to attach vacuum hose
So I know the vacuum hose attaches to the back of the petcock but then where to
Old Apr 23, 2011 | 09:18 PM
Look behind the left frame rail. Sometimes it hides there. It goes to a port next to the rear carb inlet.
Old Apr 23, 2011 | 09:56 PM
lukenukem47's Avatar
Great
Omg, I will be pulling my hair out in the near future. My project hawk is a "from scratch" build up. It's little stuff like this that has me worried. I'm tearing down two bikes to make one extremely nice one. I will be pissed if I'm without a bike this summer.
Old Apr 29, 2011 | 05:22 PM
bird
thank you hawkrider
Old Apr 29, 2011 | 08:10 PM
I take it you found the problem?
Old May 2, 2011 | 03:49 PM
bird
Actually I did not. I still have not figured out where the vacuum hose attaches to motor. Any suggestions?
Old May 2, 2011 | 04:20 PM
bird
I did read that it attaches to the rear cylinder to a connection like the one you use to tune the carbs but I cannot find any schematic with that diagram
Old May 3, 2011 | 08:54 AM
https://www.superhawkforum.com/forum...-manual-11365/
Old May 3, 2011 | 09:36 AM
It hooks to #7 :Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
Which is opposite of the CCT on the front cyl.
Old May 6, 2011 | 04:44 PM
bird
Thanks everyone for your help. Turned out it was an easy solution. Hawks flying with a fresh new paint job.
Old May 6, 2011 | 08:31 PM
CrankenFine's Avatar
I used a couple small dabs of red nail polish to index the open position, because i suffered the same confusion about open and shut. The vacuum hose connection to the REAR of the petcock is it's own separate PITA. I am going to splice the vacuum hose with an inline fitting so I never have to disconnect it again from the REAR of the petcock.
Old May 6, 2011 | 09:12 PM
Do as Greg (Hawkrider) suggests on his website for carb sync set-up. Cut the vacuum line under the left rear of the tank, between the tank and the frame in front of the seat, then put a 5/32" vacuum "T" fitting in the line and cap the 3rd opening of the T with a vacuum cap. You now have an easy disconnect and, after removing the vacuum cap, a vacuum connection to the front intake manifold for carb sync.
Old May 7, 2011 | 12:31 AM
Or do like I did... Take the freakin petcock and cut the lower nipple off, it can still vent, and now the emount of nipples and hoses match each other... That works fine for me...
thedeatons
Mar 18, 2014 09:52 PM
drsmithy
Aug 28, 2013 07:57 AM
havoc7685
Apr 4, 2012 11:10 AM
Kators
Nov 2, 2009 04:08 PM
bcunning82
Jun 27, 2009 06:38 PM
