Post accident weirdness
Old Jun 21, 2009 | 11:57 AM
So I finally got in my first ride since I was hit by that 83yr old woman, and I noticed a bit of weirdness.
Mostly that my left can was getting way hotter than the right. Pre accident both carbon fiber cans stayed basically cool to the touch no matter how long of a ride.
Now the left one gets too hot to touch while the right stays cool. I can (wearing gloves of course) cover up either one and the exhaust exits the other side just fine.
The odd thing is that nothing was/is visibly crimped. Bike seem to run fine.. So I am really perplexed by this.
Anyone have any idea what might be going on?
Old Jun 21, 2009 | 01:15 PM
BeerHunter's Avatar
Slacker
I'm not sure what to make of that. Perhaps a mud dauber built a nest inside your exhaust system somewhere. That is my best guess. Did you remove the entire system to inspect for dents on all surfaces?
Old Jun 21, 2009 | 04:56 PM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
Very odd indeed. About all I can think of is to swap the cans over and see if the RHS one gets hot.
Old Jun 21, 2009 | 06:30 PM
I think it sounds like one of the cylinders has a fresh air leak on the intake side. I don't know how or where you were hit but it sounds to me like one of the cylinders is running way lean. Glad your back up.
Old Jun 21, 2009 | 06:51 PM
cliby's Avatar
also check the exhaust mounts at the engine to be sure they are still seated properly and weren't bent/loosened
Old Jun 21, 2009 | 08:36 PM
Circuit_Burner's Avatar
guru of things sparky
Check your carbs, the carb cluster might have been jarred from thier seated positions.
Air leak city.
Check for leak between carbs and manifold, and also between carbs and airbox / filters.
Old Jun 24, 2009 | 07:16 AM
hawxter996's Avatar
ole dirty bastard
you still have stock header?
if so this is normal for the hawk
Old Jun 24, 2009 | 08:31 AM
Yep it is still the stock header.. However I remember many times checking the temp of the cans because the high mount makes them so that they are right where any passenger WILL have her feet against them. And they always were cool to the touch, in all riding conditions. But now the left one gets hot and the right stays very cool..
Old Jun 24, 2009 | 08:44 AM
hawxter996's Avatar
ole dirty bastard
cans could need repacking.
if they are carbon do so soon.
chickenstrip
Jul 11, 2009 02:46 PM
nfbzike
Sep 2, 2008 10:03 AM
Timmybung
Aug 22, 2008 10:05 AM
joshuatest
May 21, 2008 08:40 PM
floridasroadkill
Oct 20, 2006 07:19 PM
