Possible Carb Issue?
Old May 10, 2011 | 10:03 PM
  #31
Yeah shake the bike from time to time. You can even crank it a little, with the kill switch in the 'off" position to suck the cleaner up into the passages also.
Then drain it out and go from there.
Old May 11, 2011 | 10:55 AM
  #32
fred's Avatar
Mid-level Member
fred
Originally Posted by FastRED
Okay that is a great picture, seems like there is a lot more stuff to unplug and unscrew but this doesnt look too bad. If this soution doesnt work, ill be taking this apart like you have done soon.
if you don't find your shop manual, you don't even need to search. i'm posting the link to it for you (my good deed for year 2011):
https://www.superhawkforum.com/forum...-manual-11365/
--fred
Old May 11, 2011 | 11:58 AM
  #33
FastRED's Avatar
FastRED is on a distinguished road
Thanks Fred. And 8541, Mike is it? I flushed the seafoam through, let it sit for probably an hour and a half then re assembled. I took it for a spin around the block and noticed that only when in the low RPM's it spudders. Another thing i noticed was water in the flushed fluid. There might be more... I think it could be the water bogging it down or possibly the low end pilot. IDk?
Old May 11, 2011 | 12:23 PM
  #34
Yes it is Mike....
At this point it sounds like you are dealing with the water issue. Even if you are not, you need to drain the tank and get some fresh fuel as you will not know if you have it running right or not until you do.
Also add the SeaFoam to the next tank or two of fuel to make sure everything is nice and clean. After that run a little bit through the system
(like around 2 oz or so) every month or two just to keep things cleaned out (this may not be necessary where you are located but CA fuel can be pretty crappy and this does help mine run better)
Old May 11, 2011 | 01:09 PM
  #35
FastRED's Avatar
Right,
I put some fresh fuel in there only two days ago and flooded it (4oz) with seafoam. I am going to try and run it for a couple days and try to clean the system out.
Old May 11, 2011 | 01:45 PM
  #36
Right,
That should work. While the cleaner isn't "mostly" Alcohol it does have some in it which will bind with the water and help pass it through the system.
AK Ronin
May 19, 2011 08:20 PM
poppazuti
Oct 6, 2010 07:26 AM
dshakes
Jun 16, 2010 03:21 AM
skoshere
May 28, 2010 09:33 PM
minispeed
Jul 10, 2009 06:03 PM
