picture of fuel tank
i am putting my fuel tank all back on, and i am not able to see the manual very clearly as far as where all the hoses go. if someone could post a pick of what the bottom side of the fuel tank looks like, with the petcock on, i would be so grateful.
5 lines
Two big ones are easy
third big one to the tank itself
Little one that turns big goes on the tank, not the petcock
other little one goes on the side of the petcock on the left, NOT the port on the bottom/back
the little one on the petcock, it goes to the part that runs parallel to the ground. is that correct. the bike will not start. also, do i understand correctly that all the way counter clock wise is on for the fuel petcock
thank you so much for the pic. it helped out. my bike doesnt have the small tube that turns into the big tube. both of the small ones are the exact same, so i had them backwards. i hope.... anyways, the bike ran for a few, so thanks everyone for your help.
