picture of fuel tank
Old Apr 6, 2008 | 04:01 PM
macworld's Avatar
macworld
i am putting my fuel tank all back on, and i am not able to see the manual very clearly as far as where all the hoses go. if someone could post a pick of what the bottom side of the fuel tank looks like, with the petcock on, i would be so grateful.
Old Apr 6, 2008 | 04:28 PM
drew_c14's Avatar
5 lines
Two big ones are easy
third big one to the tank itself
Little one that turns big goes on the tank, not the petcock
other little one goes on the side of the petcock on the left, NOT the port on the bottom/back
Old Apr 6, 2008 | 04:29 PM
drew_c14's Avatar
if you get it back on and the bike runs for a few minutes then bogs down, the little one on the petcock is on the wrong port
Old Apr 6, 2008 | 07:02 PM
macworld's Avatar
macworld
thanks, that so should be easy enough to get
Old Apr 7, 2008 | 04:44 PM
macworld's Avatar
macworld
the little one on the petcock, it goes to the part that runs parallel to the ground. is that correct. the bike will not start. also, do i understand correctly that all the way counter clock wise is on for the fuel petcock
Old Apr 8, 2008 | 04:51 AM
macworld's Avatar
macworld
ttt
Old Apr 8, 2008 | 12:24 PM
drew_c14's Avatar
I'm going to try and get a picture for you....
Old Apr 8, 2008 | 12:54 PM
drew_c14's Avatar
These are the two lines not on the petcock as viewed looking from the front
Petcock from the front
Petcock from the rear. You can see the little vacuum line
Hope this helps!
Old Apr 8, 2008 | 08:22 PM
speedhawk's Avatar
One Wheel Wonder
speedhawk is on a distinguished road
your camera must rock. good pics. i dont know how to do it with just one person. i always have a hard time by myself without scratching anything.
Old Apr 9, 2008 | 04:37 AM
drew_c14's Avatar
I use a rubber mallet up front to prop up the tank. Gives me enough room to do everything.
Old Apr 9, 2008 | 09:10 PM
Drew, your little clamp is slid back on the petcock vacuum line. BTW, that's always the easy way to tell which is which. The small tank vent has no wire clamp.
Old Apr 10, 2008 | 02:39 AM
drew_c14's Avatar
Good eye Greg, I noticed that as I was posting the picture.
Old Apr 10, 2008 | 04:45 AM
macworld's Avatar
macworld
thank you so much for the pic. it helped out. my bike doesnt have the small tube that turns into the big tube. both of the small ones are the exact same, so i had them backwards. i hope.... anyways, the bike ran for a few, so thanks everyone for your help.
kostritzer
Jun 13, 2012 10:34 AM
Alan
Jun 20, 2008 10:22 AM
calitoz
Sep 15, 2007 04:12 PM
Brian A
Dec 1, 2006 02:00 PM
Loco
Feb 9, 2006 10:21 AM
