PAIR system block off plates
Old Sep 11, 2006 | 08:18 PM
  #31
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
I think thats everything
Old Sep 11, 2006 | 08:37 PM
  #32
Did you remove the tank? If so, is the smallest hose with the clip going to the bottom of the petcock or the back of it?
Sounds to me like a loss of vacuum, thus my thinking it's a loose hose or unplugged nipple. Double check everything. Tank vent lines, drain lines, etc., etc....
Old Sep 11, 2006 | 08:43 PM
  #33
SillyHawk's Avatar
there was a hose coming off the top of the PAIR and back to T connnection that i capped off. are you saying there is another i should have checked. this is tough without pics
Old Sep 11, 2006 | 09:13 PM
  #34
selztoad's Avatar
yeah i made that mistake it was running like CRAP but I plugged the hose and she was HAPPY again
Old Sep 11, 2006 | 09:16 PM
  #35
SillyHawk's Avatar
well @#$% i DID plugg up that vacumm hose coming off the T and it still has been very moody since this Modification...maybe when i bring it in for the 8000 service (which includes the carbs and stuff) they can fix it nice. i would say dont do the PAIR removal just based on the way my bike currently runs.
Damn, i want it to be one little thing wrong but i cant put my finger on it
Old Sep 12, 2006 | 09:04 PM
  #36
superbird's Avatar
superbird is on a distinguished road
I got the Dan Kyle plates, no complaints.
Old Sep 12, 2006 | 09:29 PM
  #37
Blurr's Avatar
Blurr is on a distinguished road
So this PAIR thing could be why I am shooting flames out the back???
So if I just disconnet it I should be fine???
Old Sep 12, 2006 | 09:39 PM
  #38
EngineNoO9's Avatar
no. pair will make it worse. the pair system burns off the excess fuel in the exhaust. disabling will make it so whatever currently is getting burned off int he pair system will now be burned off in the exhaust. your running real rich if you're shooting off flames.
I think I'm gonna be forced to order block offs... I really don't want to but our work bench is covered and it'll take me forever to make my own right now... anyone have a link to any on ebay? the ones i have linked are like $20 i believe
Old Sep 12, 2006 | 09:43 PM
  #39
Blurr's Avatar
So why is this thing running so rich??? It had D and D pipes on it before I just bought new jardines and now it pops on decel and shoot flames
Old Sep 12, 2006 | 09:46 PM
  #40
EngineNoO9's Avatar
it's your jetting in the carbs. I'm assuming you baught it with the D&D's? the jardines probably are a little more restrictive (not a bad thing) and the jets should probably be dropped down a size or the needles adjusted...
Old Sep 12, 2006 | 10:17 PM
  #41
Blurr's Avatar
Yes I bought it used with the d and d s alright so smaller jets then? or the needles adjusted???
Alright someone told me maybe the air filter sucks or raise the idle???
So dont touch the PAIR system at all?
Old Sep 12, 2006 | 10:18 PM
  #42
EngineNoO9's Avatar
in your current situation not wanting flames... yes
Old Sep 12, 2006 | 10:27 PM
  #43
Blurr's Avatar
Yeah the flames....the backfiring on decel its very annoying
So what to do, just smaller jets and stuff??
This something easy to do or
Just take it to dealer and explain its running rich???
Does raising the idle or changing the air filter do anything?
Old Sep 12, 2006 | 10:32 PM
  #44
SillyHawk's Avatar
i am pretty sure you will need to raise the idle after doing this mod...i had too. i have jardine high mounts, DYNO jet kit and stock air filter
i did the removal of the PAIR sunday and now it runs kinda crappy but less backfiring for sure!! i would probably put it all back together but its too much of a pain in the ****.
Old Sep 13, 2006 | 12:01 AM
  #45
Blurr's Avatar
Yeah well I am going to mess with the carbs and see what happens........
Old Sep 13, 2006 | 07:23 PM
  #46
Okay, I gotta jump in here about the PAIR. Removing the system WILL reduce the flames out the pipes, if not stop the problem altogether. But Blurr, you're still running rich and you should take care of it (or have it taken care of). By the time the exhaust reaches the atmosphere, it should be cool enough where it will not ignite. The PAIR system is injecting air into your exhaust system while it is still extremely hot and this is what causes the ignition. That flame travels down the exhaust and out the pipe. What do you think causes the popping on decel? Explosions in the exhaust, but Blurr is running so rich that the flame continues to burn even after it reaches the atmosphere.
Old Sep 13, 2006 | 07:37 PM
  #47
Blurr's Avatar
Yeah I am going to see about having the cabrs adjusted. It didnt do it with the other pipes just the jardines and you can see the exhaust is very black and stuff from the flames
Jack Flash
May 7, 2014 10:45 PM
inderocker
Apr 2, 2009 01:00 PM
ff
Dec 26, 2008 09:30 AM
Texassuperhawk
Dec 26, 2005 11:15 PM
CNI Dawg
Nov 16, 2005 10:07 PM
