Overcharged Battery
Old Feb 22, 2012 | 10:08 AM
climbiton's Avatar
climbiton is on a distinguished road
Overcharged Battery
Would of wise.... When putting the whole front end back together after replacing the steering bearings, remember to fully plug in all electrical.
After riding hard yesterday I found that my battery was getting overcharged. With the smell of sulfur and a high pitch tone coming from under the seat it got me worried. Well with further investigating I found that my Headlight came unplugged causing the current that should have been going to it, went right back into the battery? Nope wrong again...........
Old Feb 22, 2012 | 10:52 AM
I am pretty sure you are diagnosing this wrong.
An uplugged headlight should not cause this, more likely your regulator/rectifier is failing. This component is meant to control current in the charging system.
Put a meter on your battery with the bike running and unplug the headlight and note differences. Same reason going to hi beam wont drain the battery, nor will turn signals.
Old Feb 22, 2012 | 11:02 AM
1971allchaos's Avatar
Have to agree / truly Smokin' is correct.. Especailly if you have a 1998 to 2000 (earlier) S-hawk...
Old Feb 22, 2012 | 12:06 PM
+ a million. Replace that R/R. Your battery should not rely on external draw to operate properly. If operating correctly, the charging system will work with everything unplugged from it.
Old Feb 22, 2012 | 12:07 PM
blamecanada's Avatar
blamecanada is on a distinguished road
lol, I was like uhhh guess I overcharged the **** out of my battery at the track day where I unplugged the headlight and brake lights.
Old Feb 22, 2012 | 01:45 PM
climbiton's Avatar
Alright, I put a meter on it. At idle it rises above 15 and with RPM's at 2500 it shows 18+.... Bad R/R?
Old Feb 22, 2012 | 01:49 PM
PUSHrod's Avatar
Is this the silly political season?
Yep, bad R/R. Gonna toast the battery.
Old Feb 22, 2012 | 02:39 PM
climbiton's Avatar
OK, pulled the regulator and tested all top three prongs all test in the 40's. But the thing that I found is the plug for the regulator is melted on the top middle and right.....
Any Clues??????
Old Feb 22, 2012 | 03:37 PM
Classic r/r failure. Replace with a MOSFET unit if you can. Very common on this bike. Looked something like this, but maybe more?
Old Feb 22, 2012 | 06:16 PM
climbiton's Avatar
Thank you everyone. Yes my plug looked worst then that. Could not afford new unit, so for now I replaced it with heat resistant female connectors with silver solder on the ends of the wires. All numbers are in the norm.
Old Feb 22, 2012 | 06:20 PM
So yeah its toast. Also go to eastern beaver and replace that whole plug cuz its also done.
So...........................DO A SEARCH
(hadda say it) for the R/R or regulator rectifier on this forum because there is hours of info on it.
You want to replace it with a mofset one (NOT a stock one). I used one from an R1 like a lot of guys but other options abound.
15-18 is obviously way too high
phillip
Jan 14, 2008 11:13 AM
fundgh
Apr 20, 2007 11:38 AM
Otto Man
Feb 2, 2007 12:57 PM
Hawkrider
Jan 1, 2007 04:20 PM
Corona Hawk
Nov 8, 2006 04:19 AM
