Look at these MCCTs
Old Feb 22, 2012 | 06:22 AM
chemomche's Avatar
chemomche is on a distinguished road
Look at these MCCTs
Hi, i just saw these in another forum
are they better than the simple long bolt assmbly
Old Feb 22, 2012 | 06:51 AM
RWhisen's Avatar
Former Superchicken Owner
Those are reworked OEM CCTs that have been converted to manual.
Old Feb 22, 2012 | 07:23 AM
aja's Avatar
aja
Depending on how they're made, the most likely the same, they just use the oem plunger instead of a carriage bolt.
Old Feb 22, 2012 | 09:31 AM
killer5280's Avatar
And you can make them out of the OEM pieces for a few bucks.
Old Feb 22, 2012 | 11:50 AM
franz125's Avatar
franz125 is on a distinguished road
Finaly they dont work well.I did those in same way.In the halfe summer I got some tickering noise in the rear cilinder.First I was thinking it was valve noise but no,it was a cam chain loosening and broken rubber piece inthe top of the tensioner.So figure it out are they good or not.
Old Feb 22, 2012 | 12:42 PM
aja's Avatar
aja
He was comparing them to the other version of the home made ccts, where a long carriage bolt is used instead of the OE plunger.
I would recommend using just a carriage bolt, less pieces means less pieces that can fail.
Old Feb 22, 2012 | 11:56 PM
chemomche's Avatar
yep, that was my question
less part - less fail
but isn`t it important the part that contacts the chain slider?
isn`t this cap on the end made with some "special" shape or material?
Old Feb 23, 2012 | 07:09 AM
Well, it is a specific shape, and in theory would provide a slightly better support than the carriage bolt (a wide surface rather than the rounded end of the bolt). It's some form of metal, so I doubt the material is anything special. That being said, if it was really important, all of the racers and companies that make MCCT's would figure out a way to shape their bolts as well. If you look at where the forces are being applied, it probably makes such little difference that it doesn't matter.
I've never read about one failing correlated to the shape of the MCCT at all. And would be much more skeptical of having to deal with more pieces...
woodsrider1
Dec 31, 2011 10:20 AM
8541Hawk
Sep 6, 2011 10:07 AM
vtrlvr
Apr 19, 2007 10:21 PM
Sand&Water
Aug 25, 2006 02:16 PM
thegreep
Mar 10, 2006 06:48 AM
