Ongoing clutch issues
Old Jun 6, 2023 | 04:53 PM
B R's Avatar
B R
B R is on a distinguished road
Back a while ago clutch started slipping because seemingly too much pressure was building up in the line. I then proceeded to rebuild the slave cyl., but nothing changed.
Just this week I decided to rebuild the master cyl. I have been swapping old and new parts in the master with various results, but no working clutch.
I think the original problem, was a totally plugged compensation port. I managed to clean that out, but now I'm having the opposite problem from before. I can move fluid through the system and out the slave bleeder, but I can't seem to generate sufficient pressure to actually move the clutch. Pressure out of the master seems good, when I fill with fluid off the bike, I can generate some good squirting straight out of where the banjo port is.
It's a pretty simple system but I can't figure out what the problem is. Should I pull the slave off (again) to have a look?
Old Jun 7, 2023 | 06:27 AM
Have you tried pushing fluid from the slave to the master.
Old Jun 7, 2023 | 06:50 AM
VTRDarren's Avatar
VTRDarren
Isn't there a metal pin/rod behind the slave cylinder?? Perhaps ensure that is well lubricated, sounds like something may be stuck.
Old Jun 7, 2023 | 10:56 AM
B R's Avatar
B R
No I haven't. Seems like that would be hard to do, but I suppose I could hook up some compressed air and push it through the slave bleeder?
WIth the line disconnected at the slave, I put the slave banjo in my mouth and blew, to check for restrictions. I did get some air bubbles coming out the master when I did that.
I just bought a new/used line, and will swap that out as soon as I get it. I doubt that will fix the problem, but it's a cheap experiment.
Old Jun 7, 2023 | 02:43 PM
How does brake fluid taste?
Don't use compressed air, you don't want to introduce more air into the system. Seems I recall someone using a very large syringe, or something similar. I have used a Mityvac to pull from the slave.
Old Jun 9, 2023 | 04:19 PM
Get an really good HD syringe and reverse bleed, from the slave up. When systems get finicky, this method works great. Happens more frequently when lines become completely drained too.
Old Jun 15, 2023 | 11:01 PM
B R's Avatar
B R
Well I got the new/used line and swapped that out. Then went about bleeding the same normal way from the master. It took a little while but I eventually got good pressure and clutch engagement is back to normal. Next step is a test ride to see if it still slips under hard accel. If it does, then I'll have to put a new set of discs in.
Old Jun 17, 2023 | 10:39 AM
B R's Avatar
B R
So did about 60 miles yesterday, and clutch didn't slip at all under various combinations of gears, rpms, and throttle. Great success! Was the old line part of the problem? I don't know for sure, but at least all the hydraulics have been rebuilt now, and it cost less than $100 for all the materials. Spent many hours of my time on it though .
Old Jun 19, 2023 | 06:44 PM
sneeze
Dec 29, 2018 11:27 PM
JasChen
May 8, 2018 06:50 PM
Shriker
Jun 27, 2013 05:35 AM
psyclown
May 16, 2010 02:14 PM
ATLSHawk98
Nov 26, 2008 08:41 PM
