Oneway Brake Bleed Valve pic
Old Jan 18, 2007 | 11:58 AM
Alan's Avatar
Alan is on a distinguished road
For those who hav'nt seen one here's a pic as promised take the hassle out of bleeding your brakes,one man job
Old Jan 18, 2007 | 12:03 PM
Alan, thanks! That's about what I had envisioned. This does look like it would work well. There was another post about one-way bleeders but they sounded like replacements for the stock bleeder nipples and prone to failure. Were you able to zero in on a supplier of these?
Old Jan 18, 2007 | 12:16 PM
Alan's Avatar
Hi Nuhawk
as i said previously Hein Gericke UK sell them and the only thing that came up from me searching for the US was Fairchildsports.com who sell Hein Gericke items so maybe they can help you if not try a Quad centre (atv) as my son got this from his work (atv) other than that i suppose i could get them hear and post to the US.
Old Jan 18, 2007 | 12:36 PM
Now I remember your previous post, thanks! Most of what I see from HG is apparel. I will dig around a little this afternoon and see what I can find. Will post up from here for the others. I will have time. Heat wave today in Texas 2C at 1400.
Old Jan 18, 2007 | 12:42 PM
supertwinSH's Avatar
supertwinSH is an unknown quantity at this point
I like it! I will have to do some seaching on that little jewel.
Old Jan 18, 2007 | 12:43 PM
Alan's Avatar
Yes HG sell kit but bike parts aswell maybe Fairchild do the same but not on there web addy i dunno.
Did you say 2c?
Well its 8.30 pm here had really bad winds today (for the uk anyway) and now its pissing it down.
I wish we had a heat wave right now as there would be some loud exhaust notes rumbleing away lol
Old Jan 18, 2007 | 01:09 PM
Alan, I think this may be it. If you go to the home page for this company all these parts are under Mityvac. I think this little accessory is the part we are looking for. What do you think?
http://www.casporttouring.com/store/...ory_Code=MITYV
Old Jan 18, 2007 | 01:14 PM
Yeah! 2C!
And BTW - STSH! Pull up the sat/vapor time lapse imagery for south central USA - you're about to get hammered! Let it snow, let it snow, let it snow!
Old Jan 18, 2007 | 01:27 PM
bkelsey's Avatar
bkelsey
Here's one from my favorite offroad mail order:
http://www.rockymountainatv.com/prod...0&navType=type
Old Jan 18, 2007 | 01:40 PM
I think that's it, Kelsey! Alan said his son worked in an ATV shop. This is much closer to his picture than the one I found and I like the price!!! I think I'll order one this afternoon! Very good! Thanks, again! I think you should start a new thread now that you've located it. The Fairchild - HG link was largely a no-go!
Old Jan 18, 2007 | 03:23 PM
sprhawk neil's Avatar
I ordered the goodridge speed bleeders just waiting on my pads to get here then I'm installing front and rear s/s lines I'll post how the speedbleeders work. supposed to be a one man job.
Old Jan 18, 2007 | 03:25 PM
by the way it looks like you could make that one above with a check valve and tubing from the local hardware store???
Old Jan 18, 2007 | 03:39 PM
That's what I thought too, Neil, but I wasn't real impressed with what was said about the speedbleeders. Ordered one from the ATV place so I'll do the same when I get it.
Old Jan 18, 2007 | 04:41 PM
Alan's Avatar
Hi Guys so it looks like you can get sorted now failing that i have used a 50mm syringe before now,attach a small length of tube to srynge attach the other to bleed nipple,pump lever,draw the srynge up feeling the suction in the srynge,open the nipple,watch the air being sucked out,close nipple when no more bubbles or suction is present,repeat process.Hope this helps if you want pics let me know.Dont know where you could get the srynge i got from my local hospital free of charge.
P.S its slightly more difficult to do on your own,by this i mean pumping lever,drawing srynge,open bleed nipple,watching fluid,closing nipple.As the srynge draws the fluid through very quickly.
Old Jan 18, 2007 | 04:44 PM
I only ordered 1 package of two speed bleeders for the front if they work I'll pick up another pair for the rear and clutch
Old Jan 19, 2007 | 07:13 AM
The problem I've found with the Mity-vac and the like is that when you put a vacuum on the bleeder and you open the bleeder air is sucked past the threads and back up into the bleeder. This makes it difficult to tell when you're fully bled. One solution is to dab some grease around the threads. The other solution is to use teflon tape on the threads, but that requires removing the bleeder, which can get messy if not done correctly.
I think the check valve is the best answer to the single person bleed scenario. I may have to pick up one of those myself.
Good thread, BTW!
Old Jan 19, 2007 | 10:20 AM
Alan's Avatar
Yes Greg air does tend to enter through the thread on the bleed nipple,it does on the oneway bleeder i have,and thats exactly what i did use teflon tape to sort it,i did mention this on the 'Brake Mod Thread',ive also used a 50ml srynge as said before with great results but its a little tricky doing everything on your own this way.
tomzxt
Aug 30, 2018 03:06 PM
someonehappy
Mar 6, 2017 05:05 PM
thefitzvh
Jan 15, 2010 09:20 PM
speedkelly@aol.com
Dec 4, 2007 03:10 PM
NOrrTH
Oct 28, 2005 10:52 AM
