ok ,,so i got stock needles and jets ,,,,,,,,,
Old Apr 7, 2009 | 03:47 PM
dickard37's Avatar
dickard37 is on a distinguished road
my question is ,,, if i were to shim the needles ,do i just add a washer to the needle and thats it ? that would bring the needle UP ,,correct ??? there's already a washer there ,should i leave it and just double up washers ??? I know i'm looking to hard at this ,I know it's simple or so you say ,,i tend to think about things too hard and start second guessing ,,grrrrrr
ahhh screw it ,,,what jet kits do you guys recommend ,it'll be a hella lot easier that way ................
Old Apr 7, 2009 | 03:50 PM
You can add a washer for a richer midrange, or replace the washer for somewhat less.. It depends on how much you need to richen it..
As for which jet kit, the Factory Pro one is considered easier to install and tune, but both it and the Dynojet are quality kits.
Old Apr 7, 2009 | 04:22 PM
RK1's Avatar
RK1
I've got the Dynojet kit and I'm happy with. I've got the Honda oem filter and street baffle cans. Don't know what you have. I settled on main jets pretty much equal to the stock ones. If I was starting with stock and knowing what I know now I'd probably just shim the needles and be happy.
Old Apr 7, 2009 | 04:35 PM
nath981's Avatar
I don't think you posted enough info about your present set-up for us to provide an intelligent answer. What mods do you have? what do your plugs/pipes look like look like color wise?
Old Apr 7, 2009 | 05:29 PM
996SSVTR's Avatar
Nose Picker
996SSVTR is on a distinguished road
I was having problems with my carbs being set up right, and I spent about 12 hours trying to get it right but in the end I spent $280.00 and about 4 hours waiting on it while it was in the shop, then I was out riding again.
Old Apr 7, 2009 | 05:50 PM
dickard37's Avatar
sorry 'bout that ,,the only mods that i know of are ,two bros. carbon fiber pipes .The plugs were black sooty looking .My whole problem is ,I am getting that fart ,hic-up ,real bad even after i do a carb sync.
Old Apr 7, 2009 | 06:46 PM
If the plugs are black and sooty, you are already too rich.. Adding a washer would likely make that worse.
At what RPM do you get the hiccup?
Old Apr 7, 2009 | 07:18 PM
dickard37's Avatar
any where from 2300 to 3000 ,but it's almost constant ,spit ,spit ,buck ,buck ,spit ,hic-up ,i'll have to pull the plugs again ,the last time was a couple months ago but they looked black ......
Old Apr 7, 2009 | 07:20 PM
Easiest way to tell if you are running too rich is to pull the choke and see if it gets worse or better.. If it gets better you are running lean and if it gets worse you are running rich.
Old Apr 7, 2009 | 07:31 PM
dickard37's Avatar
yeah i've done that too ,and it does get better ,the only problem with that ,the idle drops so low it almost stalls out ,,,
Old Apr 7, 2009 | 07:32 PM
nath981's Avatar
I would definitely check the TPS and adjust to 500. Mine started that **** and that's all I did and it totally cured it.
Old Apr 7, 2009 | 08:18 PM
It gets better but the idle drops? Weird. Normally choking it will increase idle.
Checking the TPS couldn't hurt. Be careful as it is delicate.
Old Apr 7, 2009 | 08:28 PM
dickard37's Avatar
i only pull it out a pee hair , i guess i'll check into the tps ....
Old Apr 7, 2009 | 09:47 PM
500 ohm is what the manual calls for but according to Greg... "there is an advantage of better throttle response to having the TPS set at a lower value (400-430 Ω), vice the normal 800-900Ω."
refer to
https://www.superhawkforum.com/forum...TPS+adjustment
I had mine at about 500 ohms for years but with my last carb cleaning I set it at 415 ohms. We'll see if it makes a difference.
kelowna1971
Jun 1, 2013 01:42 PM
eugeneutopia
May 20, 2008 02:34 PM
supermarto
Nov 14, 2007 04:21 AM
trinc
Oct 13, 2007 06:13 PM
Syclone
Oct 6, 2007 10:21 PM
