ok and it happened again
Old Jul 29, 2011 | 02:24 PM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
i have another issue. alright reving about 2- 2500 rpm stady throttle (in neutral) the engine sputters and drops about 500 rpm and then comes right back.... it dose this every few seconds.
i am thinking it is the carb but i am not sure what the problem might be or where to start looking. can anyone help?
Old Jul 29, 2011 | 02:52 PM
wsharpman's Avatar
99 superhawk
well I wouldn't be a good candidate to tell you as mine is awaiting a new r/r, but mine does the same thing around 2200-2500rmp it hesitated and sputters (even pops some) anything over or under it runs ok. I don't get the 500rpm ever tho it's lowest is 1000 rpm on idle (usually is 1200rpm).
anywho I am watching your post as well to see if maybe its carb or not then it tells me if I also need to take mine and get carbs sinc'd (betting on that being it).
Old Jul 29, 2011 | 03:04 PM
jay956's Avatar
search carb fart
Old Jul 29, 2011 | 03:11 PM
3amta3's Avatar
i rev it to 2k--2500 sitting still... and it basically farts so to speak, or you could call it burp
it just started doing it today... man this POS is driving me crazy....... i always get lemons and can not be turned into lemonade.
Old Jul 29, 2011 | 03:56 PM
jay956's Avatar
if u search the forum its been discussed quite a few times on how to fix it. or just dont hold it at that rpm, you shouldnt be riding in that range anyway.
Old Jul 29, 2011 | 04:15 PM
wsharpman's Avatar
99 superhawk
as I am not technically savvy on messing around with a carb I just ignore it and ride around the little quirk. my bike only has 11.2k on it now.
Old Aug 3, 2011 | 05:46 AM
3amta3's Avatar
i fixed mine, if you need info on what i did write back and i will post it. busy right now so cant now but will later.
hirschmj
Jun 25, 2007 08:13 PM
StoneJrW
May 8, 2007 08:38 PM
Hawkrider
Apr 10, 2007 06:12 PM
khanawalt
Apr 6, 2007 01:48 PM
Brian A
Forum Feedback
Sep 20, 2005 07:57 PM
