ok and it happened again
i have another issue. alright reving about 2- 2500 rpm stady throttle (in neutral) the engine sputters and drops about 500 rpm and then comes right back.... it dose this every few seconds.
i am thinking it is the carb but i am not sure what the problem might be or where to start looking. can anyone help? |
well I wouldn't be a good candidate to tell you as mine is awaiting a new r/r, but mine does the same thing around 2200-2500rmp it hesitated and sputters (even pops some) anything over or under it runs ok. I don't get the 500rpm ever tho it's lowest is 1000 rpm on idle (usually is 1200rpm).
anywho I am watching your post as well to see if maybe its carb or not then it tells me if I also need to take mine and get carbs sinc'd (betting on that being it). |
search carb fart
i rev it to 2k--2500 sitting still... and it basically farts so to speak, or you could call it burp
it just started doing it today... man this POS is driving me crazy....... i always get lemons and can not be turned into lemonade. |
if u search the forum its been discussed quite a few times on how to fix it. or just dont hold it at that rpm, you shouldnt be riding in that range anyway.
as I am not technically savvy on messing around with a carb I just ignore it and ride around the little quirk. my bike only has 11.2k on it now.
Originally Posted by wsharpman
(Post 310098)
anywho I am watching your post as well to see if maybe its carb or not then it tells me if I also need to take mine and get carbs sinc'd (betting on that being it). i fixed mine, if you need info on what i did write back and i will post it. busy right now so cant now but will later. |
