oil type honda HP4M hi perform 20W-50 synth/ pet blnd w/ moly good or bad?
Old Aug 1, 2012 | 06:12 PM
hupmanmj's Avatar
hupmanmj is on a distinguished road
I just got an 03 Hawk about 2 weeks ago and it has a stock engine and exhaust system. no mods that I am aware of and It needs an oil change as it hasn't had one since last season. I am thinking about running honda 20W-50 HP4M synth/ petrlm blend w/ moly. or I could run w/o moly. or from what I have read on other oil related threads (not an easy topic to find surprisingly) Mobil 1 20W-50 would be a good choice as well.
any thoughts about the HP4M w/ moly vs w/o moly? thanks,
Old Aug 1, 2012 | 06:17 PM
saige's Avatar
the boss
make sure for one,any oil you use is not energy conserving at all.
10w/40 is plenty good.
easy bet would be to use mobil1 vtwin syn motor oil.you can get it at walmart for 8 to 9 a bottle.
or even the auto part store,which can run a dollar or 2 more.
Old Aug 1, 2012 | 06:18 PM
saige's Avatar
the boss
https://www.superhawkforum.com/forum...erencing-7884/
Old Aug 1, 2012 | 07:59 PM
GTS's Avatar
GTS
Seasoned tech
I like running factory oil so the Honda stuff is preferred. With moly if you want to spend the extra coin. But as you seem to have indicated you've already found everyone has an opinion on oil so run what seems to work for you. Just make sure it's motorcycle oil. Automotive oils don't have the proper additive package in them for the transmission gears as well as for the wet clutch.
Old Aug 1, 2012 | 08:08 PM
hupmanmj's Avatar
thanks for the advice. ill keep it in mind when I pick up the oil tom afternoon sometime.
Old Aug 2, 2012 | 01:30 AM
Honda recommends 10w40. I wouldn't use anything heavier. I've used Pro Honda GN4 since my bike was new, and it's got over 62,000 miles on the clock.
I don't know what advantage molybdenum in the oil would have, but I've never payed extra for "special oils". Arco made a graphite oil back in the 1970's, and it smelled like salami when it burned.
Did I just answer another oil thread?
Yeah, you did... And so did I...
Don't use cooking oil, and don't use energy conserving oil... Other than that, it's a free for all...
Old Aug 2, 2012 | 08:18 AM
For a stock system, why not run a stock weight? 20w-50 seems pretty thick... although it's not cooking oil so I may be overly concerned, haha!
Old Aug 2, 2012 | 02:04 PM
twinman's Avatar
twinman is on a distinguished road
U cant use moly cause of the wet clutches
Old Aug 2, 2012 | 02:52 PM
thetophatflash's Avatar
I've run the 20w-50 Honda with moly for 13 years and ran a similar blend from Schaeffer in my 500 Interceptor for 14 years. The interceptor shifted smoother and I believe the Hawk does too, but it's been so long ago that I switched the difference is not very strong in my old data bank. lol
Old Aug 2, 2012 | 04:19 PM
ascothawk's Avatar
ascothawk is on a distinguished road
I remember that graphite oil,it didn't work to well in my 73 big block Monte Carlo that needed valve seals. The graphite would burn and form carbon deposits that would bridge the electrode and ground strap on the plugs in just a few days. Of course it was always the hardest plug to get to. A change back to conventional oil and all was good.
Old Aug 2, 2012 | 07:36 PM
hupmanmj's Avatar
thanks for all the input. I read a lot about oil in the last few days and decided to go with HP4 10W-40 w/o molly. I think that this is a good starting point and it is the viscosity called out in the owners manual anyways. I found an article that i thought was a good read, but now can't seem to find it. ill find the link and post it later. thanks again
Old Aug 9, 2012 | 03:12 PM
GTS's Avatar
GTS
Seasoned tech
It's made for motorcycles with wet clutches so I think it's just fine to run in these bikes if you so choose.
Gabe
Aug 13, 2015 09:22 PM
ChikinLady1011
Aug 14, 2013 04:00 PM
twist
Mar 29, 2013 10:45 PM
dsevans
Jan 1, 2009 01:20 PM
BirdofParadise
Mar 15, 2006 04:47 PM
