Odometer frozen
Old Jun 1, 2012 | 04:25 PM
20_rc51_00's Avatar
Odometer frozen
So.... my speedo has been acting up for some time bouncing/not moving at all, I realyl didn't care much. I also had a problem with some current drain from the trip meter which I simply remedied with removing the fuse for that circuit, again didn't care much.
But today I noticed something a little different. The odometer is frozen at 69204, and didn't change through out an entire tank that I ran through the bike today. Any ideas or suggestions?
Old Jun 1, 2012 | 05:17 PM
BeerHunter's Avatar
Slacker
Sounds like the speed sensor has stopped working. Run the tests in the Service Manual and report back what you find.
Old Jun 1, 2012 | 06:20 PM
20_rc51_00's Avatar
Yup will do.
Old Jun 2, 2012 | 04:44 AM
CrankenFine's Avatar
The wiring diagram indicates the trip meter and odometer are on the same power wire from the fuse block. (any year)
You killed your odometer when you pulled that fuse.
Old Jun 2, 2012 | 06:58 AM
20_rc51_00's Avatar
not true, pulled the fuse and the odo still worked fine, so did the trip (except the trip would always reset to 0 if the bike was turned off. the odo would work as normal. I used it like this for months.
Old Jun 2, 2012 | 08:42 AM
OK I am stumped. The fuse is clearly indicated to provide DC to the odo and trip meter on wiring diagrams in the factory manual for both types instrument cluster. It must run on FM.
Old Jun 2, 2012 | 09:24 AM
BeerHunter's Avatar
Slacker
The fuse he pulled labeled 'A' is the keep alive memory for the tripmeter and is always hot. The odometer still gets power from the speedometer power wire through the 'E' fuse When the ignition is switched ON.
Old Jun 2, 2012 | 09:25 AM
saige's Avatar
the boss
that means someone messed with the wiring at one point and either put a wire in the wrong place,or hooked up some wires to the power source,which means its key on/off.does not run thru the fuse box.
gonna have to trace wires and put it back to normal.
it sucks,but you may find other problems.
Old Jun 3, 2012 | 12:58 AM
Or you could just listen to beerhunter, since he hit the mark on this one...
Old Jun 3, 2012 | 10:40 AM
saige's Avatar
the boss
lol,yea,i meant to edit post,cause his did sound alot better,was just to lazy after that.
Old Jun 5, 2012 | 08:05 PM
20_rc51_00's Avatar
so the speedo and odo are working just fine again. It apprears that there is some sort of looseness bte the connector fo the speedo healer unit and it's own harness.
Old Jun 6, 2012 | 02:00 PM
BeerHunter's Avatar
Slacker
That is my favorite kind of fix, the kind that doesn't cost any money!
Are all the pins fully engaged in the connector?
Old Jun 6, 2012 | 03:19 PM
20_rc51_00's Avatar
They are now anyways. I had to fasten the whole body of the speedo healer in a different way so that there is some tension against the connector otherwise the same thing happens. I'm not sure how to tighten the prongs against the pins for as a better solution. Also it appears that the vibes of the hawk have caused loosening of the plastic of the male and female connector so there is a less retention between the two.
Old Jun 16, 2012 | 03:51 PM
justinjbaron's Avatar
justinjbaron is on a distinguished road
Hi,
I have the symptoms described by the original poster.
I followed the instructions in the manual for troubleshooting.
I don't have a stand (and didn't have a friend with me), so I couldn't get the rear wheel off the ground to test for the voltage pulses from the sensor. But I did decide to test the voltage from the sensor at rest, and it has constant 4.7V ?
I am guessing that this concludes that the sensor is faulty - meaning, the voltage should have measured zero? I just wanted to check here as I am not all that electrically inclined and want to make sure I am interpreting this correctly.
(If this is the issue, anyone happen to have a sensor for sale? I checked the classifieds section and didn't see any actively for sale)
If I have to replace this, anyone know if the parts are different from later model Superhawks? I have a 1998. If the newer sensors have been revised to be better, and they are backward compatible, I'd want to get the newer one.
Thanks in advance!
JB
Old Jun 16, 2012 | 03:55 PM
saige's Avatar
the boss
only the 98 to 2000 model sensors will work for your hawk.
2001 and up have a different speedo all together.cant use those sensors.
Old Jun 16, 2012 | 04:17 PM
BeerHunter's Avatar
Slacker
Yes the speedometer is different above 2000 models, but the speed sensor is the same replacement part for all years!
SENSOR, SPEEDOMETER
37700-MBB-010 (replaces 37700-MBB-000)
Old Jun 16, 2012 | 04:43 PM
BeerHunter's Avatar
Slacker
Originally Posted by justinjbaron
Hi,
... so I couldn't get the rear wheel off the ground to test for the voltage pulses from the sensor. But I did decide to test the voltage from the sensor at rest, and it has constant 4.7V ?
I am guessing that this concludes that the sensor is faulty - meaning, the voltage should have measured zero? I just wanted to check here as I am not all that electrically inclined and want to make sure I am interpreting this correctly....
JB
The voltage reading will depend on the position of the exciter ring of the transmission in relation to the magnet on the speed sensor.
Try simply rolling the motorcycle either direction slowly while watching the meter. Place the multimeter up on the tank so you can see it.
Old Jun 16, 2012 | 04:46 PM
saige's Avatar
the boss
crap,foiled again lol
Old Jun 16, 2012 | 05:19 PM
BeerHunter's Avatar
Slacker
HaHA! Don't get discouraged, keep hammering at it and one day you will miss your thumb more often!
Old Jun 16, 2012 | 05:44 PM
saige's Avatar
the boss
lol,it seems i keep having these brain farts and dont think correctly.but why only on this thread ugggggg
Old Jun 16, 2012 | 09:12 PM
I sorta did this, how far would I need to roll the motorcycle to invoke a voltage change? I moved it about a parking space's worth of distance.
Will try again tomorrow to be sure.
Really appreciate the replies.
JB
Old Jun 16, 2012 | 09:41 PM
BeerHunter's Avatar
Slacker
I would think a parking space length should be enough to provide several pulses. Sounds like a bad sensor. Unbolt it from the case, pull it out and check for a large mound of metal particles clinging to the magnet. If so wipe it off, put it back together and test again. If there is only light buildup, I would call it a bad sensor.
Ohh, welcome to the SuperHawk Forum!
Old Jun 16, 2012 | 09:54 PM
Thanks! I just bought my SuperHawk yesterday!
1998, hasn't been dropped, bought from original adult and fairly maintenance-inclined owner. 26K on it. It needs a few things but overall I am psyched. It's a lot of bike for a first bike but I am taking things slow.
Thanks again for the replies.
Justin
roisman
Jun 15, 2011 12:36 AM
20_rc51_00
Dec 26, 2010 07:46 AM
Fozzy Bear
Aug 8, 2010 02:25 AM
BlackHawk04
Jun 28, 2008 08:39 AM
mikecronis
May 21, 2006 09:49 AM
