odd hesitation after needle shim & TPS adjust
Old Jul 2, 2008 | 09:51 AM
snowman666's Avatar
snowman666 is on a distinguished road
I have a 2004 superhawk (12000 mi) jardine high mounts. Pulled the carbs and put two washers in the slides to raise the needles also set the TPS to about 525. Starts and runs fine with no load. At crusing speed, 5k rpm, i get a stumble from the motor and an occasional backfire through the carbs, twist the throttle wide open and it stumbles and acts down on power. Question; sticking slides, vacuum leak, one washer to many, carbs out of sync, fouled plugs, what do you think, just trying to get an idea of what to check when i tear this thing back down? oh and i checked the pvlir already.
Old Jul 2, 2008 | 10:29 AM
codfish124's Avatar
SuperCock roster
codfish124 is an unknown quantity at this point
i had that happen when 1) i had bad gas or 2) the bike i have didnt come with an air lid so when i got one and put it on did the same thing. took it off and runs like a champ.
also what is the alidatude there in ohio i was told where im at leave the carbs alone the needels are for mid range gas flow medering so if it happens at WOT and just falls on it face maybe take a shim out
Old Jul 2, 2008 | 12:41 PM
Gregw's Avatar
That's weird, sounds like a lean condition. Maybe check vacuum and carb boots.
Old Jul 2, 2008 | 03:17 PM
BeerHunter's Avatar
Slacker
If you installed 2 washers on each needle then I would imagine taking one out will help solve this problem. Also, leaning out the mixture screws will be required, if you have not already done so. You have changed 2 things that will make the engine more rich at idle~1/8 throttle opening. 1. TPS adjustment lowers the timing advance curve, less advance necessitates less fuel. 2. Raised needles (too far?) allows more fuel to enter the engine at high vacuum levels (small throttle opening). The best method for adjusting mixture screws is with the engine idling at full operating temperature. Go in as far as possible (lean) without any drop in RPM. Otherwise, just turn the screws in 1/2~3/4 turn and then test ride.
You could also throw in a high flow air filter to help lean out the mixture.
Old Jul 3, 2008 | 02:59 AM
filter69's Avatar
Thats Mr Dill hole to you
And def. sync your carbs after all that horsin round
Old Jul 3, 2008 | 05:56 AM
snowman666's Avatar
i'm gonna pull everything apart, double check the tps, go down to one shim on the carb needles, and try to do a carb sync. I made a homebrew carb sync tool with some tubing, yard stick and atf. I already have a "T" in the line going to the rear of the petcock and an extension tube on the front cylinder port. I'm pretty new to carb work so this is all a learning experince = I've never done any of this before. I'll post and update when i get to ride again, looks like it gonna rain for days
Old Dec 7, 2008 | 05:28 PM
Stevebis1's Avatar
Any word on this, Snowman? I just got a used K&N so I figure some carb work is in my future. As a first step I was going to try shimming so I'm interested in anyone elses experiences.
Old Dec 7, 2008 | 06:15 PM
RickB's Avatar
I have a k&n with shimmed needles, using a .026 thick #4 brass washer and the bike runs very well.
Old Dec 7, 2008 | 08:31 PM
jbaxx's Avatar
Honducati
I had the same problem the first time I pulled my carbs apart.
Pull the airbox cover off and look at the carb slides. Slide them open with your finger, then release. If they slide back slowly, they are normal. If one of them snaps closed, you probably mis-installed the diaphragm and it is leaking.
From the service manual:
"Install the diaphragm/vaccum piston into the carburetor body. Lift the bottom of the piston with your finger to set the diaphragm rib in the groove of the carburetor body and install the spring and vaccum chamber cover".
I glossed over that part...
Unzie57
Feb 3, 2013 05:58 PM
lazn
Mar 2, 2009 10:04 AM
ViperBoy
Jun 20, 2008 08:43 AM
00996rider
Mar 29, 2005 07:40 PM
ClevelandSuperhawkRumble
Mar 25, 2005 01:27 PM
