Non adjustable TPS?
Old Jul 22, 2020 | 12:36 PM
Inland Viking's Avatar
Inland Viking is on a distinguished road
Non adjustable TPS?
I was going to mess with the TPS on my bike, and find that it is non adjustable.. There are some odd anti tamper screws... Is this on certain years only? Maybe just CA models? I am going to remove them and put in some regular screws... I just thought it was odd...
Old Jul 22, 2020 | 04:31 PM
CaryDG's Avatar
They're all that way. The factory uses shear screws when installing. Most take a Dremel or similar device to slot the existing screws (pictured). Some use the same screws to secure when done, some of us replace them with phillips or Allen head screws
Old Jul 22, 2020 | 04:33 PM
CaryDG's Avatar
You might want to sync your carbs and set idle before setting the TPS as throttle position has a direct effect on TPS readings.
Old Jul 23, 2020 | 07:24 AM
Take a look at the knowledge base section. All kinds of useful info that will save you the time of asking a question already thoroughly discussed.
https://www.superhawkforum.com/forum...n-sensor-9876/
Old Mar 24, 2021 | 12:50 AM
Alikxo's Avatar
Alikxo is on a distinguished road
In my 93 5.0, I experience had motor difficulties that lead me to beleive I have an awful or inappropriately changed choke position sensor. I took it to my companion, a repairman with a little shop, and he said that my sensor was not customizable. He said I should simply purchase another one. He has a F-150 with a 5.0 in it, and he said he needed to do something very similar. He said some are movable, some aren't. I thought all EFI 5.0 horses had a flexible TPS.
Tutuapp 9Apps Showbox
Old Mar 24, 2021 | 06:11 AM
What in tarnation are you talking about? Do you own a VTR? No one here give two ***** about a ford motor...
xeris
Dec 31, 2017 10:46 AM
skoshere
May 11, 2009 07:51 AM
Hardhead
Aug 1, 2008 02:51 PM
Reb
May 21, 2008 06:38 PM
TheRezyReb
Apr 25, 2008 02:50 PM
