no power
Old Dec 15, 2013 | 11:25 AM
ranchomice's Avatar
no power
Anybody have a clue what would cause no power...overnight? I ride the bike yesterday, no issues at all. I did not plug in the tender, but dead overnight?
Old Dec 15, 2013 | 01:29 PM
Wicky's Avatar
Dead battery caused by faulty R/R ??
Old Dec 15, 2013 | 02:16 PM
ranchomice's Avatar
Haven't put a meter on anything but it's definitely pointing towards the battery. I know nothing about working on bikes. When I plugged in the tender it doesn't indicate that it's charging. Is that an indication of a disconnect somewhere, or just a completely dead battery. I bought an aftermarket rr from a member here last year.
Old Dec 15, 2013 | 03:32 PM
Wicky's Avatar
If you describe the problem better then it might be possible to narrow it down
How old's the battery?
Do the lights come on or is it completely dead? Main fuse?
Do the lights come on and the starter clicks? Not enough juice to turn it over - knackered battery.
What kind of R/R; genuine Honda finned R/R ? or cheapo Chinese copy ? or FH marked Mosfet R/R?
Old Dec 15, 2013 | 04:34 PM
ranchomice's Avatar
Battery is about 6 months old. No lights, no nothing. 3 volts at battery measured in dc. I'm an hvac guy. Lol
I just disconnected the rr and found one connection burnt. Trying to put a photo up. Don't know what type/brand rr, but it stinks like it got hot/fried.
Old Dec 15, 2013 | 04:35 PM
ranchomice's Avatar
Where is the main fuse? Dumb question to those who know, but I don't.
Old Dec 15, 2013 | 05:33 PM
Wicky's Avatar
Look on the left hand side on the/by the starter relay for the main fuse. Definitely from what you describe you'll be needing a new R/R (get a FH marked mosfet) and battery - if you're really unlucky you might have fried other electrical components.
Here's a link to the VTR1000F (Superhawk) Firestorm Service Manual PDF
98-03_VTR1000F_NoRestriction.pdf
http://www.mediafire.com/?5u5qsfqgh9f9ejg
Removed restrictions in the Honda Superhawk (Firestorm) Service Manual PDF and was able to run it through OCR so the manual is now text searchable - Enjoy
Old Dec 15, 2013 | 05:40 PM
ranchomice's Avatar
I still have the stock rr that I replaced while it was still good, but I'll be getting another! I'm hoping I didn't burn other components! Thanks man.
Old Dec 17, 2013 | 11:15 AM
ranchomice's Avatar
Thanks for the manual. All i have is a phone, but it's on here! Put the stock rr back on and the battery is charging. To check the main fuse, can I just ohm it out like any other fuse?
Old Dec 17, 2013 | 12:25 PM
Yes. Although if you turn the key once the battery is charged and the lights go on, then the fuse is good.
Also, this R/R is prone to failure and I'd take a read through Tweety's mosfet R/R thread and upgrade yours. If you're already seeing burnt connectors then you're likely to have another failure.
https://www.superhawkforum.com/forum...why-how-25117/
Old Dec 17, 2013 | 02:44 PM
ranchomice's Avatar
The burnt connections came from an aftermarket rr I bought from someone here! It lasted about a year. The stock one was still good when I replaced it. I'm just putting it in there to see what other issues it may have caused. Now I can't find my key!
Old Dec 17, 2013 | 03:02 PM
Burnt connectors are burnt connectors... you may be creating resistance that will certainly not help the health of your currently installed r/r
madmike
Apr 24, 2007 02:25 PM
Corona Hawk
Mar 28, 2007 05:15 PM
drkwaterdiver
Nov 8, 2006 07:23 AM
penst8grad
Sep 14, 2006 07:51 AM
itsjason13
Jul 31, 2006 04:04 PM
