New Chain and Sprocket
Old Dec 5, 2012 | 01:34 PM
pchrist's Avatar
pchrist is on a distinguished road
So i was looking for suggestions for a new chain and sprockets for my super hawk she is pretty much down for the season now and i am looking at making this change for the spring. Was thinking about doing a red chain on it, red bike? this is what i found so far good bad or indifferent?
520 Conversion Kit - Superlite RS7 Steel Sprocket Set
Also what will changing the number of teeth on the sprockets gain me? Right now the bike has plenty of power and top speed for me!
Any advice would be greatly appreciated.
Old Dec 5, 2012 | 02:02 PM
Wicky's Avatar
Have a search for sprocket threads as this has been discussed many times.
Personally I would just slap in a decent heavy duty X-ring 530 chain and use an auto scottoiler and ride....
http://www.scottoiler.com/uk/products/vsystem-kit.html
Old Dec 5, 2012 | 02:07 PM
https://www.superhawkforum.com/forum...-thread-29406/
https://www.superhawkforum.com/forum...version-29439/
https://www.superhawkforum.com/forum...s-my-sh-29397/
https://www.superhawkforum.com/forum...erience-28116/
https://www.superhawkforum.com/forum...nge-log-28206/
https://www.superhawkforum.com/forum...g-today-26577/
Old Dec 7, 2012 | 09:51 AM
pchrist's Avatar
Ok so for my options what would be the best? I think i want to change to the 520 so i don't have to put the oiler on. Would 16 43 take first gear out of use? I also think i need to get a speedo healer as well. Any good recommendations out there???
SELECT FRONT SPROCKET SIZE
  • 14T
  • 15T
  • 16T - Stock
  • 17T
*SELECT REAR SPROCKET SIZE
  • 43T
  • 44T
  • 45T
  • 46T
Old Dec 7, 2012 | 10:13 AM
Out of the choices listed I would run 16\43, which is as low of a final drive ratio that I would run on a SH.
Old Dec 7, 2012 | 10:15 AM
pchrist's Avatar
What about going to a 15\? to be close to stock
Old Dec 7, 2012 | 10:33 AM
Stock is 16\41.
With a 15 front you can run a 41 and be close to the same as 16\43.
My opinion on lower final drive than that is fairly well known.
Old Dec 7, 2012 | 12:25 PM
HRCA#1's Avatar
The rule of thumb has always been to use as tall a C/S sprocket as you can pull and fine tune the gearing with the drive sprocket. Honda's are always slightly under geared on top giving them a slight overdrive in 6th, going to a 43 tooth just corrects that.
HernandoMan
Apr 15, 2015 09:12 AM
duran
Aug 27, 2007 07:57 AM
call me phil
May 1, 2006 06:32 PM
mikecronis
Feb 6, 2006 10:34 AM
RVO27
May 10, 2005 01:53 PM
