My Superhawk makes a "whining" sound
Old May 24, 2007 | 07:41 PM
BMDailey's Avatar
BMDailey is on a distinguished road
Hello. My Superhawk makes a whining sound. The sound seems to be coming from the engine area. Any info would be greatly appreciated. My bike has sounded like this for a year, and if there is something I can do, I would like to do it. Thanks
Old May 24, 2007 | 10:00 PM
Which side of the motor? Based on engine speed or road speed? High or low rpm? Please provide more info. A sound clip wouldn't be a bad idea either if you have the resources.
Old May 24, 2007 | 10:21 PM
nineighthawk's Avatar
nineighthawk
More than likely it's the cam chain. Mine whines pretty good.
It has for the last 15k miles.
Old May 24, 2007 | 10:35 PM
It shouldn't whine. I think if it whines then it may be too tight. You have APE's or stock?
Old May 25, 2007 | 05:19 AM
mkimber's Avatar
mkimber is on a distinguished road
Mine whines also. It sounds exactly like a supercharger to me and everyone else. It is most noticable at idle and low revs. The bike has 5K miles and the stock tensioners.
Old May 25, 2007 | 05:27 AM
falcondrvr's Avatar
falcondrvr is on a distinguished road
mine makes this noise as well and has for as long as i've had it (from 8000-13000 mi). somebody on here once suggested that it sounded like a Jetson's mobile and i think that's pretty accurate. to me it seems normal. i've got stock CCTs.
Old May 25, 2007 | 05:38 AM
Sgt Rock's Avatar
That's interesting because mine has had the same whine you mentioned for over two years now.
Old May 25, 2007 | 09:07 AM
Cleveland's Avatar
Post Whore Junior
Mine also. Bought bike last April 06 had 6000 miles on it, now has 15000 on it. Made the sound from the day I got it. I just assumed it was the water pump impeller, or just a characteristic of the engine. I heard a TL got by my shop the other day, and it made the same sound only LOUDER. May have been due to stck pipes on the TL.. I cant hear dick over my pipes... (shortened Erions by half)
Old May 25, 2007 | 10:36 AM
swordfish's Avatar
I think we've established that this is a normal sound. the explanation I got from a guy at my local shop was that all V-twins with overhead cams make the noise to some degree. its the price we pay for not having to adjust the valves until the 18,000mile mark. ducs are gear actuated, so they don't whine, but they need more frequent maintenance. pushrods, same thing, but overhead cam engines can rev way higher than pushrod(harley). just gotta learn to live with it. RC51, TL1000, KTM superduke, they all whine.
Old May 25, 2007 | 12:14 PM
Babelfish's Avatar
Babelfish is on a distinguished road
Ducati is very far from gear driven, they are belt driven.
Old May 25, 2007 | 11:08 PM
swordfish's Avatar
belt "driven" yes, but aren't the valves gear actuated?
Old May 26, 2007 | 12:46 AM
BiggDaddyKool's Avatar
BiggDaddyKool is on a distinguished road
my (new to me) 4300 mile engine has the same whine.
Old May 26, 2007 | 04:56 AM
Babelfish's Avatar
No the cams are belt driven and the valves are actuated by a adjustable fork that push or pull the valve. Much like a gear selector fork, but adjsutable gap.
Old May 27, 2007 | 07:54 AM
Birdoprey's Avatar
I thought it was the primary drive. lots of bikes do it, Hondas maybe moreso.
Old May 29, 2007 | 11:53 AM
swordfish's Avatar
well I guess I stand corrected. are the 4 valvers set up different? I could have sworn that I heard ducati's have gear actuated valves.
Old May 29, 2007 | 10:19 PM
The old bevel drive Ducks had them. I think they're all belt driven now.
This is a bevel drive: http://twistingasphalt.com/index.php...engine-cutaway
This is the modern 1098 motor: http://www.ducati.com/en/bikes/my200...del=SBK1098-07 Click on ENGINE.
Old May 30, 2007 | 07:57 AM
Babelfish's Avatar
And here's the desmo system used on all their bikes nowdays.
I was a bit confused in the beiginning whan I saw this drawing as it use a return rocker arm spring but it's not used to actually lift the valve, but only to apply a light pressure when closed. Therefore a much lighter spring than on conventional DOHC machines.
hondahawk
Dec 10, 2014 01:27 PM
saige
Jul 30, 2010 04:14 PM
Little_Horse
Sep 9, 2009 07:14 PM
Death Cattle
Apr 11, 2008 10:41 AM
saxman
Jun 21, 2007 05:11 PM
