My baby is sick
My baby is sick
Here's my problem. Upon light acceleration, (assuming it is just during this time as I can not hear once the 2 brothers get excited) I hear a knocking noise coming from the engine area. I haven't been able to pinpoint it better than that, you know... its coming from underneath the tank somewhere.
It sounds like a sort of soft hollow knocking sound rather than a solid metal on metal a ping. It also doesn't knock all the time... only happens after letting out the clutch and mainly notice it in 1st and 2nd gear. More common when it is warmed up but not limited to that. There doesn't appear to be any loss in power and the knocking increases with rpms. So thats the problem.... anyone have any thoughts? I love my baby and don't like her to sound troubled.
I would have some thoughts about where to start investigating but the whole clutch senario destroys all my thoeries. So I dunno.. I know computers not bikes....
i had some major problems with hawk a few months ago. mine has always done that too. i was running the bike off of coke bottles full of has and was workin on the carbs and ignition at the time. the noise comes from the carbs themselves. it is almost like a backfire... but obviously there is no fire in the carbs. it could be some kind of compression coming back up from the cylinders. im not too sure. mine only does it when its cold. my bike runs 100% right now, and it still does it.
The bike is known to have carb slide rattles at idle or low rpm, if you or someone else had the clutch or the ignition advance apart its easy to not get it back together just right which causes a knocking noise - btdt
Haven't tried it in neutral like that.. next time I ride it, ill give it a try and let you know.
I would definitely inspect the chain and sprocket aera, the torque pulses may send your chain ratteling against hard parts. If it's while you dump the clutch (friction and slipping) it may be the clutch chattering
Good luck with this, these problems are somewhat hard to trace
