Motor connections question
Old Aug 15, 2011 | 01:18 PM
OK so the motor is nearly swapped but what are the large nipples on the top of the cylinder heads? Pair system? I blocked off the pair valves so can these be covered? Also where does this small connector from the front of the motor go? I think its the pulse generator but cant find the connection
Attached Thumbnails Motor connections question-pair-001.jpg   Motor connections question-pair-002.jpg
Old Aug 15, 2011 | 02:00 PM
zmaniv's Avatar
Those large nipples are for the vent lines to the air box. Not sure about connector
Old Aug 15, 2011 | 02:23 PM
Wicky's Avatar
speedo sensor connector? Does it come from the back of the engine nr the CCT?
Old Aug 15, 2011 | 02:35 PM
OK so nevermind those 2; I got em,, where does this blank nipple off the right motor go?
Old Aug 15, 2011 | 02:45 PM
darkember's Avatar
darkember is on a distinguished road
That looks like the return cooling circulation pipe from the carbs. Refer to page 115 in the official VTR service manual.
Old Aug 15, 2011 | 03:58 PM
+1 Show us where it comes from.
And the other connector does go to the one of the bottom nipples on your front carb.
Old Aug 15, 2011 | 04:30 PM
OK found that out when I went to reinstall the carbs. Now what are these hoses off the carbs?
Old Aug 15, 2011 | 04:40 PM
saige's Avatar
the boss
gas lines going to petcock on gas tank.
Old Aug 15, 2011 | 04:44 PM
DOH!!!!!!!!!! THANKS SAIGE! I am doing so much connecting, wrenching etc I am getting loopy. Should be running by tomorrow.
Old Aug 15, 2011 | 05:07 PM
saige's Avatar
the boss
lol,yea thats understandable,after awhile it all looks the same.
Old Aug 15, 2011 | 05:28 PM
Don't forget to put the gas tank back on!
Old Aug 15, 2011 | 06:55 PM
One curveball is that some of the hoses were still on the new motor so there were some doubles. Plus I have several other excuses if you're not buying that one.....
Old Aug 15, 2011 | 07:07 PM
saige's Avatar
the boss
so how many drinks are you in on this lol
Old Aug 15, 2011 | 07:38 PM
Keep 'em coming! I forgot to actually hook up the fuel hoses when I took the carbs out a few weeks ago. But, I did remember to hook up the petcock vacuum line and hit the starter. End result: spewed gas all over my rear cylinder... that was a good one!
zxbud
Mar 3, 2012 02:22 PM
nfbzike
May 6, 2008 06:24 PM
Ausie996
Apr 21, 2007 04:13 AM
mikstr
Apr 14, 2007 05:15 PM
GautamCity
Nov 9, 2006 08:15 PM
