missing at 5000 revs
Old Apr 10, 2009 | 10:52 AM
ozzie9962's Avatar
ozzie9962 is on a distinguished road
ive just got this bike its missing at 5000 revs i have put new plugs air filter changed the cdi unit also changed carbs ,im wondering if when the last owner had it he changed the cct and it 180 out of timing how can you tell and how do i reset the timing ive tried everything possible to make this bike run correct and im losing faith i even put the standard exhausts back on please help cheers john.
Old Apr 10, 2009 | 10:58 AM
Little_Horse's Avatar
2nd mouse gets the cheese
check compression, if that specs than I would check valve timing seeing as you mentioned the prior cct replacement. One tooth off can give it a miss.
Old Apr 10, 2009 | 11:20 AM
ozzie9962's Avatar
timing
yes i no that but how do you adjust the timing thats the problem im having i dont no how to adjust it any idea cheers john.
Old Apr 10, 2009 | 02:04 PM
Ignition timing is not changeable, unless you buy a timing advancer which is basically a different profile sprocket of sorts.
Valve timing requires you to remove both valve covers and inspect the cam sprocket alignment marks are in the right place. If someone messed up the cct install its possible your valve timing is off.
Old Apr 10, 2009 | 02:07 PM
also you might need to check your Throttle position sensor is set right, and that it is plugged in, and not broken.
Old Apr 10, 2009 | 09:49 PM
ozzie9962's Avatar
throttle position sensor
can anyone send a picture of this and where it is so i can check thanks john.
Old Apr 10, 2009 | 09:57 PM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
on the right side of the aft carb... Please read the maintenance manual, we cannot help with all the misinformation you keep giving in different posts! pick one and keep your problem in one post, so we can follow and maybe help.
LB
Old Apr 10, 2009 | 10:53 PM
Truckinduc's Avatar
Also should sync the carbs
Old Apr 10, 2009 | 10:55 PM
ozzie9962's Avatar
carbs
the carbs have been done cheers.
Old Apr 10, 2009 | 10:57 PM
Truckinduc's Avatar
what do you mean by "done"
Cleaned, new seals, rebuilt?
Old Apr 10, 2009 | 11:06 PM
ozzie9962's Avatar
sync
i put new carbs on and they have been synced its exactly the same as when i had the old carbs on cheers john.
Old Apr 10, 2009 | 11:21 PM
Truckinduc's Avatar
New carbs or a different set? You synced them after you put them on your bike?
Old Apr 10, 2009 | 11:45 PM
ozzie9962's Avatar
different carbs
put different carbs on then synced them
Old Apr 11, 2009 | 01:21 AM
fighter hawk's Avatar
chopped and screwed
fighter hawk is on a distinguished road
I know you may hate me for posing this but my truck was missing above 4000 it was a coil so may be test both of them on your bike.
1150NakedHawk
May 22, 2013 04:13 PM
V-king
Jul 8, 2010 07:09 PM
Vega (streetfighter)
Jan 12, 2009 01:46 PM
VoodooDog
Sep 20, 2007 07:19 PM
