low rpm ticking...while idle and under 2,000
Old Feb 13, 2012 | 08:15 PM
meanhawk98's Avatar
meanhawk98 is on a distinguished road
I can.hear it while.riding at low tons and cruising and I can hear in in my helmet... What could it b??? Please help can.tensioner???
Old Feb 13, 2012 | 08:25 PM
RWhisen's Avatar
Former Superchicken Owner
Could be you need to shim your valves.
Old Feb 13, 2012 | 08:36 PM
meanhawk98's Avatar
Is that an ok.job to take on if I have mechanic exsperience?
meanhawk98's Avatar
And would that only happen at low rpm?
Old Feb 14, 2012 | 05:39 AM
RWhisen's Avatar
How many miles on your Hawk? Mine "ticks" too, not too loud but it's there and I have manual CCTs. I think it's the nature of the engine but we can work through things for your piece of mind. Vavle adjustment, while a little of a pain in the ... are not that difficult. Do you have the stock CCTs? Did you get your "vibration under acceleration" sorted out?
Old Feb 14, 2012 | 07:47 AM
meanhawk98's Avatar
Well mine just rolled over to 35,000 on Sunday. I just got the bike in early December.seemed to b well taken care of.I've done oil in it and coolant.not plugs or air filter yet tho. The ticking does kinda worry me.its always kinda there.I talked to a Honda shop around my area they said $700 for a valve job.... It's does have the stock ccts I havnt changed because I'm not to clear on the process of the Manuel ones in installing them.
And no I havnt I checked the motor.mount bolt all seemed ok.I'm stumped on that on to
Old Feb 14, 2012 | 08:05 AM
RWhisen's Avatar
The first thing I would do would be to download the service manual from this site. Second would be to study the KB articles on manual CCT changes. Perhaps there are some of our members out there to give you a hand on this project? I wold pull the rear wheel to investigate the vibration thing. At the very least have it balanced. Valve shims are pretty easy to do and someone who can distinguish K from KE rivets ought to be able to do it after reading the service manual.
This guy is selling a whole engine for $900 as an example of how expensive the stealership is on that valve job:
https://www.superhawkforum.com/forum...goodies-27546/
Old Feb 14, 2012 | 08:16 AM
meanhawk98's Avatar
Ok that's awesome.I'm guna do exactly that ill go and have the rear wheel balanced and have tma closer look at the chain and sprocket. And ill download the Manuel and possibly give this a try hahayou have been more then helpful thank u very much.oh and I am on the look out for Italian red left fairing and rear fairing and a new seat if u come across anything thanks again for ur help I sent u a friend request.
whats a good front and rear sprocket combo if I want just bit bit more pick me up when coming out of a corner? Mine seems to lug a bit I'm only 6 foot 200 pounds so I figure it should have a bit more pull.and it just started to kinda make a valve noise when starting out from a stop light just like. Car would if u lugged it up a big hill at 35mph and 4th gear haha
Old Feb 14, 2012 | 08:39 AM
RWhisen's Avatar
Here's a good thread for gearing:
https://www.superhawkforum.com/forum...16-43-a-27160/
Don't forget to look at the cush drive while you have the rear wheel off.
Old Feb 14, 2012 | 09:09 AM
Your ticking could be the carb slides or an exhaust leak....
As for more power out of the corners..... have you tried twisting the throttle? Maybe keep the rev's up a bit by proper gear selection before entering a corner?
Old Feb 14, 2012 | 10:34 AM
meanhawk98's Avatar
I hit the.corner in.second doing 25 seems to lug
Old Feb 14, 2012 | 10:36 AM
meanhawk98's Avatar
Thank rwhisen u.have been more then helpful and can I ask what the cush drive is?
Old Feb 14, 2012 | 01:14 PM
Probably just the carb slides ticking on the bottom of their travel. At higher rpm they will still bounce a bit but will be higher, hence the reason it doesn't happen at higher rpm.
Old Feb 14, 2012 | 01:29 PM
meanhawk98's Avatar
Ok that would make sense. I.just checked my chain.seemed a bit.loose could that cause a vibration?. And I wana do plugs what.kinda of plug should I run and what do I gap it to?
Old Feb 14, 2012 | 04:45 PM
25mph in 2nd....well there is your problem, that is around 1500 rpm, or you are lugging the **** out of it.... that is why you have first gear.... Keep the rev's up and you will not have any problems...
Old Feb 14, 2012 | 07:35 PM
Yeah, keep it above 2500 and you should be fine.
Old Feb 14, 2012 | 07:42 PM
tomzxt's Avatar
Light Cycle Expert
Rubber that fills a gap inside the wheel. When you remove the rear wheel I believe it is the sprocket side that comes apart from the wheel. In there you'll see these rubber pieces I'm talking about. If the rubber holding the two sides together is broken they can roll around in there making that side of the wheel clang about.
Looks like this:
http://www.cyclepedia.com/wp-content...BR_07_1113.jpg
Here's the technical explanation:
http://en.wikipedia.org/wiki/Cush_drive
Old Feb 14, 2012 | 08:08 PM
meanhawk98's Avatar
Oh wow ok awesome.u really have been such a huge help thank u.I'm guna do that this.weekend.i wana do spark plugs to what.kind should I use and what should I.gap.them to? Thank again so much!!
ZERO
Jan 20, 2015 06:12 AM
KAB
Jan 5, 2014 07:59 PM
Derek Perry
May 2, 2013 03:39 AM
Sablotny
Oct 19, 2008 03:34 PM
PHPERFORMANCE
Nov 2, 2006 03:49 AM
