Low Fuel Light question
Old May 17, 2010 | 01:42 PM
maverick's Avatar
I was looking to wire up a low fuel light on my hawk, but I've never had one. It looks like they're an LED on the 98-00 model... but they have three leads. Is it a muticolor led? Like green when you have fuel and red when you don't? Thanks a lot.
Old May 17, 2010 | 01:47 PM
It's a resistance sensor connected to a curcuitboard in the stock gauges... Without that you wont have much use out of the sensor...
Old May 17, 2010 | 06:41 PM
maverick's Avatar
really? It was my understanding that before 98 it was simply one led, not a fuel gauge, and the schematic in the manual simply shows an led.
Old May 17, 2010 | 07:06 PM
Yes, its just one LED...
But it's 12V going through a resistor in the tank that senses not being in the gas, going too the gauges where a small board drives the resistor... The LED does not like 12V and making the circuit to have a change in resistance turn on a LED means you will need new LED's fairly regularily as they will go POP! They aren't too fond of changing voltage... Or you need at the very least a transistor in there and some other parts... I can probably make the circuit fairly easy... (It's my work to design circuits, on a whole different scale though)...
If you look in the exploded view of the gauges in the first page of the "lights/meters" part of the service manual you see a small circuit board wedged between the two clocks... Thats the RLOD circuit...
ima98chickenhawk
Apr 21, 2014 01:57 PM
VTArrrgh!
May 13, 2012 09:39 AM
Jetfever
May 13, 2011 03:23 PM
Jetfever
Jul 7, 2005 10:58 PM
