Krieger MCCTS
Old Dec 27, 2011 | 02:46 PM
woodsrider1's Avatar
woodsrider1 is on a distinguished road
Krieger MCCTS
Woohoo! Installed my Krieger ccts today. All was going well till I broke a valve cover bolt while reinstalling it. Thank goodness the local Honda shop had 2 of them in stock. Everything is back together now with fresh oil and filter as well. It is now running (sounding) better than it has as long as I've owned it. Rain moved out just in time to take it out for a test ride. Felt so good to be back on it after a month long deployment and down with a bad front cct. Caught it before any damage was done thanks to the info on this site. Props to everyone!
Old Dec 27, 2011 | 02:58 PM
aja's Avatar
aja
Those bolts snap way too easily. Check the with a torque wrench if you have one, they should be around 10
Old Dec 27, 2011 | 03:54 PM
The Honda manual I have says 7 ft lbs. The bolt showed signs of being partially broken. Thats problably the only way it broke with a torque wrench set to 7
Old Dec 27, 2011 | 05:02 PM
aja's Avatar
aja
I broke a good one at 8lbs, and I also had a cracked one when I pulled it out. It's not fun drilling for an easy out with an open head haha. They really only need to be tight enough for the rubber gasket to make a seal, which isn't much more than hand tight.
Old Dec 29, 2011 | 06:38 PM
klx678's Avatar
Just hangin' out
klx678 is on a distinguished road
I don't know about the VTR, but a lot of the Hondas and others don't even tighten down on the gasket, they just squeeze them. The bolts or the spacers in the covers bottom out and tightne up either on the step flange of the bolt or spacer. No matter how tight you tighten the bolts the gasket squeeze is only as tight as the spacing allows. Thus it is a very good idea to use a torque wrench. I know that was how the Wing valve cover was, as is the KLX. Pre-set squish on the gasket and the bolts bottom out on a flange.
Old Dec 29, 2011 | 07:34 PM
Yep, that's exactly how these ones work. I've snapped a couple b/c the PO tightened them down like a regular bolt. It weakened them so that when I tightened to spec they just broke off... not a fun time when it's one of the last steps usually lol!
Old Dec 30, 2011 | 05:45 AM
klx678's Avatar
Just hangin' out
Shoot, they ought to have those double head bolts where the top snaps off when at the proper torque for some people! Of course it would be both cheaper and easier to simply use a torque wrench too, but that would be asking those who destroy stuff to do something they seldom completely do - think!
Old Dec 30, 2011 | 07:08 AM
You can still break stuff with a torque wrench... took me a try or two to figure out that Nm isn't a fancy way of writing ft/lbs ha!
Old Dec 31, 2011 | 10:20 AM
klx678's Avatar
Just hangin' out
Damn metrics! Communist plot I tell ya!
Everything should be in Whitworth I tell ya! Now how would that work... hand/stone?
Bandit400man
May 22, 2012 01:37 PM
chemomche
Feb 23, 2012 07:09 AM
Rad_Draven
Feb 14, 2012 04:33 PM
vinkate
Feb 14, 2012 07:54 AM
vetlad1954
Jul 3, 2011 02:23 PM
