Longer throttle cables and.....
Old Dec 22, 2007 | 01:39 PM
redman's Avatar
Still on my 954 front swap stuff.
Had to tweak a few things and Dremel a couple of teeny spots on the fairing underneath as the bottom triple bolts were hitting and wrangled the horn up and out of the way as well. Now I am trying to get the dang throttle cables and brake lines to work. Looks like I need about two extra inches on the throttles and some angled end fittings on the brake lines....aaargh! Any of you know of longer throttle cables? Must be someone out there as many have gone to regular bars on top of the triples.........I'd hate to have make cables from scratch...I've done it but it's a pain.
Old Dec 22, 2007 | 02:16 PM
superbling's Avatar
Sorry don't have a length for you but I used VFR cables (02-present) on my current superbike bar swap.
Got a friendly dealer? Go to their parts dept. when it's slow and have them match up a set.
Old Dec 22, 2007 | 02:33 PM
redman's Avatar
Thanks SuperB, just hit Ebay and there are many cheap ones from earlier vfrs. Do you know the difference? They look the same but....
Old Dec 22, 2007 | 09:26 PM
Thumper's Avatar
Motion Pro made a set longer for my conversion on an SV650S. I gave them the model bike and how much loner than stock they needed to be. Fir perfect and top quality.
I recall it was around $60 for the pair. Just call the direct and bypass the local dealer....
Old Dec 24, 2007 | 02:41 AM
Reinske's Avatar
Reinske is on a distinguished road
Hey,
I also have the 954 fork in my SH. Got it with wider fork bridges even and my throttle cables still fit. A bit straighter, but it's ok. Got it quite close to the fairing. Works without any probs...
Old Dec 24, 2007 | 08:23 AM
redman's Avatar
Thanks all, for the input. I am using the 954 triples too and they are wider. I am riding again but when at 3/4 to full lock, left or right, the throttle cables are very stretched and kinked, respectively, and longer ones would allow me a bigger loop and avoid all that. I'd hate to be pulling in tight to my garage at almost full lock right and have the throttle stick wide open...
Old Dec 26, 2007 | 12:03 PM
Lefin102's Avatar
+1 for Motion Pro they made longer cables for my 1/5 race throttle install. $30 a cable. Good luck
UCF Eric
Dec 15, 2014 06:14 PM
WildmanVTR
May 11, 2010 11:10 PM
Truckinduc
Sep 22, 2009 05:25 PM
skokievtr
Nov 16, 2007 12:30 PM
MisterMohawk
May 29, 2007 08:35 AM
