Longer throttle cables & wiring?????
Old May 9, 2010 | 06:35 PM
WildmanVTR's Avatar
WildmanVTR is on a distinguished road
So I may do the super bike hanblebar and risers and mod my top triple clamp. I'm actually going to use some Pro Taper Low Bars that came off a TRX 450 R 4 wheeler. After I make, mod, or get different risers, I know that I will need to extend the wiring and the throttle cables will need to be longer. Any suggestions on cables that are longer from some other model? I figure I can make some wiring harnes extensions by using some used ends & wiring.
Old May 9, 2010 | 08:50 PM
slabm7's Avatar
How much riser do you plan on having? I just did the superbike bars with 2 inch risers which gave me a lot of pull back and rise with the bars and had alot of slack in the throttle cable and wiring. I had to replace the brake lines but everything else reached quite easily.
Old May 9, 2010 | 10:10 PM
I don't think you'll have to extend the wiring, just the cables and hoses. You can use a set of throttle cables from an F4i and then get yourself some steel braided lines and you'll be set. I've also got some LSL clamp-on riser's if you're interested.
Old May 9, 2010 | 11:06 PM
luis saleiro's Avatar
luis saleiro is on a distinguished road
What model is F4i Inde?
Old May 9, 2010 | 11:19 PM
CBR600F4i
Old May 10, 2010 | 12:36 AM
Man you´re fast!
Thanks.
So, you´re saying the throttle cables from the CBR 600F4i fit´s in the SH in order to extend it, is that right?
I´m only asking cause i´m also putting a pro taper in mine, and this worries mi too.
Old May 10, 2010 | 12:58 AM
Yeah, I'm about 98% sure
Old May 10, 2010 | 04:19 AM
WildmanVTR's Avatar
Thanks guys! That's what I was looking for. I'm only going with 2" risers myself. I know I'll need a new brake line, I just didn't know if the throttle cables would be long enough.
Old May 10, 2010 | 11:17 AM
How much do you want for the "LSL clamp-on risers (Spiegler)? I thought Spiegler's "kit" fit on the OE top triple clamp.
http://www.spieglerusa.com/cfm/sbk.cfm
Old May 10, 2010 | 12:46 PM
That's just a general pic. The VTR kit uses the "AS" style.
I'll take $100 for the clamps, but since I offered them up to Wildman first I'll wait and see if he wants them.
Old May 10, 2010 | 09:37 PM
If Wildman does not want the Spieglers and I take them, I have a OEM top triple clamp Wildman can buy from me to use as a basis for his SB bar/riser mod; which is what I was going to do.
Wildman???
Old May 11, 2010 | 11:10 PM
moving on... PM sent.
Wildman???
UCF Eric
Dec 15, 2014 06:14 PM
Truckinduc
Sep 22, 2009 05:25 PM
redman
Dec 26, 2007 12:03 PM
skokievtr
Nov 16, 2007 12:30 PM
MisterMohawk
May 29, 2007 08:35 AM
