License plate Lights
Old Jul 29, 2010 | 08:55 AM
pwshadow's Avatar
pwshadow is on a distinguished road
Im going to put an integrated turn signal/brake light in and was thinking of just zip tieing the license plate on. Does anyone know if you are obligated to have the license plate lit up?
Old Jul 29, 2010 | 09:01 AM
nothing's Avatar
ride it out
Here it's necessary in order to pass inspection. I think it's the same everywhere, except FL and some other states where you don't need an inspection.
Old Jul 29, 2010 | 09:03 AM
pwshadow's Avatar
dont need an inspection here
Old Jul 29, 2010 | 09:13 AM
Well there is no inspection here but you can be stopped and issued a ticket for it.
Old Jul 29, 2010 | 09:30 AM
pwshadow's Avatar
I searched but didn't find much. Is there a previous thread on home made fender eliminators?
Old Jul 29, 2010 | 09:42 AM
Well the integrated light that I got has a plate light in it. So by moving the plate up under the taillight it gets lit.
Old Jul 29, 2010 | 09:48 AM
pwshadow's Avatar
Where did you get your light at?
Old Jul 29, 2010 | 09:51 AM
Ebay, it was the cheap LED integrated one
Old Jul 29, 2010 | 10:00 AM
alwayshonda's Avatar
alwayshonda is on a distinguished road
It looks like you should be ok. Here's what I found.
(1) Every motor vehicle other than a motorcycle shall be equipped with at least two head lamps with at least one on each side of the front of the motor vehicle, which head lamps shall comply with the requirements and limitations set forth in sections 42-4-202 and 42-4-204 to 42-4-231 and part 3 of this article where applicable.
(2) Every motorcycle shall be equipped with at least one and not more than two head lamps that shall comply with the requirements and limitations of sections 42-4-202 and 42-4-204 to 42-4-231 and part 3 of this article where applicable.
(3) Every head lamp upon every motor vehicle, including every motorcycle, shall be located at a height measured from the center of the head lamp of not more than fifty-four inches nor less than twenty-four inches, to be measured as set forth in section 42-4-204 (3).
(4) Any person who violates any provision of this section commits a class B traffic infraction.
Source: L. 94: Entire title amended with relocations, p. 2242, § 1, effective January 1, 1995. L. 2009: (1) to (3) amended, (HB 09-1026), ch. 281, p. 1272, § 38, effective October 1.
Old Jul 29, 2010 | 10:06 AM
nothing's Avatar
ride it out
A license plate light is another lifeline from people rear-ending you at night time, IMHO.
Old Jul 29, 2010 | 10:11 AM
Not sure why the headlight stuff is relevant here... but anyways.... Those integrated are illegal here in Ca but that is of no real concern either.
After trimming my rear fender, I did the old school mod to get a license plate light. What you do is install a clear piece of plastic (cut out a small section on the bottom of the tail light and install a clear piece, or leave it open if you don't mind your tail light filling up with crap) in the bottom of the tail light which allows the tail light to also illuminate the license plate.
Old Jul 29, 2010 | 10:15 AM
I just copied the whole section. I got a pair of Tag Boltz from here:
http://www.customdynamics.com/illumi...#LED_Tag_Bolts
They have leds for extra turn signals at the ends too. Like nothing said, it's yet another lifeline.
Old Jul 29, 2010 | 01:41 PM
bjorn toulouse's Avatar
Destructive Tester
Here in oHIo a non-functional license plate light is Probable Cause for the cops to pull you over.........the fact that oHIo plates are highly reflective not withstanding.
Rex
Old Jul 29, 2010 | 01:43 PM
Required in Texas.... I used a set of Tag Boltz on mine.
Old Jul 29, 2010 | 02:43 PM
RWhisen's Avatar
Former Superchicken Owner
As I do.
Old Jul 29, 2010 | 02:46 PM
mortbike's Avatar
mortbike is on a distinguished road
Florida laws
$1,000 fine in Florida if license plate is not properly lighted and visible or if any reflectors are removed!
Old Jul 29, 2010 | 03:40 PM
RWhisen's Avatar
Damn, they tag you for the reflectors too?
Old Jul 29, 2010 | 04:00 PM
pwshadow's Avatar
Those tag bolts are pretty sweet. Harbor Freight has 9in strips of different colored water proof leds for like 9 bucks. I was thinking of putting a strip of blue ones in the radiator intakes. Maybe i will just put a strip above the plate too. Kind of have a nice blue glow all over the bike.
Old Jul 29, 2010 | 08:41 PM
98ILVTR's Avatar
Required here, but my LED taillight is so bright, that I don't use one.
AZZKIKER
Nov 30, 2011 04:48 AM
nophr
Feb 3, 2011 06:52 PM
CNI Dawg
Jul 1, 2006 04:05 PM
Vincent
May 26, 2006 02:33 PM
2Phaast
Nov 22, 2005 04:01 AM
