Left exhaust is hotter than right exhaust
Old Jun 5, 2010 | 09:27 AM
Anwar's Avatar
Anwar is on a distinguished road
Got a 98 with 2 yoshi RS-7, maybe RS-5 but probly rs-7. its been dumped on the left side too, the pipe steming from the center leading to the pipe is crushed. I can text pictures but thats the best I can do. The guy who did it must've sealed it up because theres like welding marks over where it would be open and is sealed pretty good. Some hot air comes out around the weld though, theres small cracks from the material used to seal the pipe. And so the left pipe has a dark ring on the outside, and the right looks silver. any ideas?
Old Jun 5, 2010 | 09:35 AM
Anwar's Avatar
should add that their RS-3's
Old Jun 5, 2010 | 10:00 AM
Anwar's Avatar
Question left exhaust hotter than right
the left side was dumped and badly scraped. RS-3 exaust. the bottom of the pipe where it comes out to side is half smushed, sealed up to reapair for air leaks. but leaks out in a couple different spots. and when i start it up the air out of the left is hotter than the right. i havent remebered to check if it does that after riding a while, but it does do it when its readily idling to ride. should i replace the exhaust? or the pipe just below it thats crushed, both?
Old Jun 5, 2010 | 11:19 AM
doomcookie's Avatar
doomcookie is on a distinguished road
I think its normal, I'm no expert but my left pipe is always hotter at start up.. even with me taking out the restriction on the right side.. I think its normal
Old Jun 5, 2010 | 11:30 AM
ranchomice's Avatar
The superhawk has a strange exhaust design that seems to flow better on one side. I think that's all you're experiencing. If it's different at the header (leaving the head) that would indicate a problem.
Old Jun 5, 2010 | 12:03 PM
It's not only strange, it's downright complicated engineering and hours on a dyno. The best header in the business is the stock header.
On any header one side always (at idle) heats up quicker and seems to flow more air. This is hard to check at a hundred miles per hour. Most of the aftermarket stuff that was available in the heyday of the Superhawk were fancy bends and welds and zip for tuning. The ones that cost around a thousand bucks were at least as good as the stock header - very few were better.
Make sure you check the exhaust bushings at the heads (easy access) the the joint under the swing arm - even easier.
Crashed exhaust is trashed exhaust.
In my book, but that's not completely true. Hawkrider had a post where he put water in the tube and then put it in the freezer wrapped it in a towel ??? It's back there but it might be worth a read if you're on a budget.
Old Jun 5, 2010 | 12:18 PM
Anwar's Avatar
thanks alot
Old Jun 5, 2010 | 02:43 PM
I merged the threads
Old Jun 5, 2010 | 07:50 PM
bjorn toulouse's Avatar
Destructive Tester
THANX A LOT!!! I just sprayed my monitor with a big gulp of Dr. Pepper!
Rex
jonjonsocal
Oct 26, 2014 11:29 PM
amazin
Feb 15, 2011 04:01 PM
inderocker
Jan 12, 2009 10:26 AM
little squirt
Oct 27, 2008 08:16 AM
call me phil
May 25, 2007 03:57 AM
