LED flasher unit problem
Old Jan 30, 2010 | 12:36 PM
pwolski's Avatar
pwolski is on a distinguished road
Hi guys,
I just installed front and back LED turn signals. They work great with the stock flasher relay except for the fast blink rate. I wanted to have a clean install and no resistors so I purchased the electronic LED friendly flasher from Clearalternative. After plugging in the LED flasher I get no response from the turn signals. The factory relay has three pins, LED two pins with an adapter for the factory plug. Any ideas, it is the weekend and Clearalternative is closed???
Thanks,
Pawel (Paul)
Old Jan 30, 2010 | 01:22 PM
Gregw's Avatar
Did you wire it up like this?
Old Jan 31, 2010 | 09:25 AM
pwolski's Avatar
Thanks for the quick reply. I used your set up, but still nothing (I have yellow-live and black-ground lead on the relay). There is something loose in the relay box, I can hear it when I shake it. Will have to call Clearalternative on Monday.
Once again, thanks for your help.
Pawel.
Old Jan 31, 2010 | 10:46 AM
thetophatflash's Avatar
Do the flashers work with the old relay reinstalled? I switched to a similar unit(LP) when I put on new signals. It was plug in and go.
Old Jan 31, 2010 | 03:31 PM
pwolski's Avatar
Yes, they work with stock relay (just flash too fast). I must have a defective unit.
Old Feb 1, 2010 | 06:42 PM
pwolski's Avatar
Called Clearalternatives and they are shipping a new relay at their cost. The guy was very nice.
Old Feb 2, 2010 | 10:21 PM
KingJerd's Avatar
KingJerd is on a distinguished road
Try yellow ground, black live. Thats how my rear LED turn signals are. Its weird but thats the only way they work.
Old Feb 3, 2010 | 03:05 PM
pwolski's Avatar
Thanks, I did reverse the wires, but still no blinkers. The new one is in the mail.
Old May 3, 2010 | 02:24 PM
amazin's Avatar
amazin is on a distinguished road
Whatever happend with this? was wondering if clearalt had decent flashers
RWhisen
Dec 5, 2013 01:09 PM
amazin
May 18, 2010 01:27 PM
johnclopp85
May 27, 2009 08:23 PM
Erik S.
Jul 19, 2008 08:40 PM
Les
Feb 12, 2006 12:23 PM
