Klunk/ metal sound
Old Mar 9, 2009 | 06:26 PM
skoshere's Avatar
Klunk/ metal sound
So today I took the bike out for a short ride... when crusing at 3k-3.5k, i get a noticable metal klunkly sound, kind of a metal thud sound...
Any ideas on what it could be? The bike has stock CCT's in it at 20k, I have APE's going in Saturday... could that be the noise?
Any help would be great....
Old Mar 9, 2009 | 06:48 PM
HisHawkiness's Avatar
Never heard the sound of a failing CCT personaly but that seems to make sense....id quit riding the bike until you put the CCT's in just to be on the safe side and see if that resolves the problem
Old Mar 9, 2009 | 06:59 PM
Trust me...That's not the CCT's... That sounds like gravel in a washing machine and once it starts it doesn't stop at any rev's until the bike is toast or repaired...
Doesn't mean it's a bad idea with a CCT change...
Noise like that can be many things... And not all logical... We have had people with a loose drive chain, carb backfire and many other things give that same description as you...
Find out more... The rpm's isn't info enough to figure it out...
Old Mar 9, 2009 | 07:05 PM
skoshere's Avatar
i noticed I get the sound when I fill with gas... This is the second time I heard it when I filled with gas... when I rode it agian after gas sat in the tank, I did not hear/feel it
Old Mar 13, 2009 | 11:21 AM
skoshere's Avatar
UPDATE MORE DETAIL
So i had a good ride today in 35 degree weather.
More details on the noise/feeling....
when cruising in the 3 - 4K range I feel a pulse klanking noise from under the gas tank area. I can feel the bike stumble ever so slightly. I then roll on the throttle and it is fine during accleration, but when cruising it reappears.
Is this gas combusting in the carb? Any help would be great.
Old Mar 13, 2009 | 12:04 PM
hawxter996's Avatar
ole dirty bastard
kinda sounds like it may be spitting back through the carbs.
any changes or mods?
when stock mine was barely rideable.
it would spit clunk and stall on me all the time.
i installed a dynojet kit and all that and the surging idle went away.
Old Mar 13, 2009 | 02:13 PM
reaper's Avatar
I have a similar sound, but mine happens when the bike is cold and it is coming from the front cylinder. It sounds like there is slack in the cam chain. Erring on the side of caution, I have decided to replace the CCT's. I would recommend doing the same, it is cheap insurance.
Good luck.
Old Mar 13, 2009 | 02:56 PM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
Carb sync. Easy to do, makes the bike smoother, and may get rid of your noise. I agree with the earlier poster, it sounds like backfire through the carbs.
Old Mar 13, 2009 | 03:07 PM
reaper's Avatar
Honda has Hawxter stated his bike would barely run with the backfiring of the carbs. Skoshere stated his problem happens at 3-4K rpms, so if it were the carbs the problem would cover a wider spectrum of issues not just in that specific rpm range.
Old Mar 13, 2009 | 03:14 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
Carb slides rattling?
Old Mar 13, 2009 | 03:51 PM
skoshere's Avatar
i am figuring with my slip on pipe, i am either running lean and there fore having the issue. I plan to jet and sync the carbs soon.
Old Mar 13, 2009 | 04:20 PM
thetophatflash's Avatar
I had this same problem a number of years ago. i suggest that you are missing one or both rubber cushions at the rear tank mount.
vinkate
Nov 7, 2012 04:21 PM
j shizzy wizzy
Jun 27, 2011 07:56 PM
foundmikey
Apr 9, 2011 01:38 PM
dsevans
Dec 31, 2008 05:47 AM
ejizzle
Jan 3, 2007 02:18 PM
