JE pistons and Stage 2 Cams
Old Jan 18, 2018 | 05:25 AM
Bald Eagle's Avatar
Bald Eagle is on a distinguished road
I am sure this has already been asked (cause I am still a SQUID) but is it safe to run JE Pistons (11.5:1) with Mori Stage 2 Cams without going too stupid with this modification. Also what would be the spark timing adjustment for the JE Piston compression to the original piston?
Thanks
Old Jan 18, 2018 | 05:46 AM
You may want to contact Roger Ditchfield of Revolution Racing in the UK for this type of information (he did development work on racing VTRs for both HRC and Moriwaki). Your main concern may turn out to be getting the crank to last as stock cranks running aggressive cams tend to let go...
Old Jan 18, 2018 | 09:53 AM
You will also need to source valve springs as STG2 cams will not work with the stock springs.
Old Jan 18, 2018 | 02:44 PM
Bald Eagle's Avatar
I was going to get the springs from WebCam.
Old Jan 20, 2018 | 08:15 AM
fabiostar's Avatar
as above it will need the springs to stop it all getting a bit messy..
CruxGNZ
Mar 23, 2016 10:21 AM
98VTRrider
Oct 7, 2013 05:41 AM
Tebs
Sep 23, 2013 07:43 PM
FL02SupaHawk996
May 21, 2009 05:04 AM
seaton001
Jan 3, 2008 03:42 PM
