Install Heads and cams??????
Old Sep 25, 2011 | 07:29 AM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
ok i have a few questions:
i just had my heads redone and i got them back and am ready to put them in the bike but i am confused. i know the bike sparks every time around so position really does not matter but. when i install my heads and cams i am trying to figure out what stroke i am on so i can find TDC on the compression stroke so i can set up the cams to match. i am not sure what cylinder to start with do i set up the from cylinder first or the rear?
if anyone can help please call me. 301-769-one two two nine
Old Sep 25, 2011 | 09:51 AM
Phone call made......
Old Sep 25, 2011 | 11:06 AM
3amta3's Avatar
thanks for the sanity check, mike right? if i have any other questions i will post and maybe you can give some ideas. i will have it running tomorrow and i hope it runs right.....
Old Sep 25, 2011 | 12:55 PM
3amta3's Avatar
i just fired it up and it sounds ok. i still have a slight knock/rattle though, not sure what else to do to this thing. other than tear into the bottom end i have done everything i can think of. i am at a loss.
Old Sep 25, 2011 | 12:58 PM
msethhunter's Avatar
Could be the starter sprag clutch. I remember seeing something about a mod you can do to help the noise. Lem'me check.
Edit to add: Found it.
http://www.fireblades.org/forums/hon...tml#post993156
Old Sep 25, 2011 | 02:03 PM
3amta3's Avatar
i have had all of that apart and checked over. like i said i have done everything besides split the case for the bottom end.
i started the bike again and let it warm up a little, stood it up straight and the noises seamed to go away. i have yet to ride it to see if the rattle is still there, i will be riding it tomorrow and hopefully it will all be normal.
locouno5.0
Feb 14, 2013 12:12 PM
driven
Dec 7, 2008 05:09 AM
mikstr
May 3, 2007 02:24 AM
Rollingalong
May 5, 2006 03:04 PM
