increasing idle
Old Mar 30, 2010 | 06:22 PM
Fish's Avatar
increasing idle
Bike starts fine, even in 40 degree weather. As she warms up the idle increases to above 1500 RPM. Stage 1 jetting, needle at #5 w/o shim,slides drilled, and set-up as per instructions. 2 Brothers full exhaust and looks to be running a bit rich by looking at the plugs. No PAIR system.
Any suggestions?
Thanks
Fish
Old Mar 30, 2010 | 06:57 PM
killer5280's Avatar
Any suggestions?
Thanks
Fish
How much above 1500 RPM? Once the engine is warm does the idle remain constant?
If the idle is too high for you turn the idle adjust screw counterclockwise a little bit.
Old Mar 30, 2010 | 07:01 PM
cliby's Avatar
if it idles fine and as warms it increases might be lean at idle. did you adjust the fuel-mixture screws when you set it up? are the needle clipped at #5 from the bottom slot on the needle or #5 from the top of the needle?
there is a procedure for adjusting the fuel mixture screws that is pretty straightforward and might be a good starting point.
Old Mar 31, 2010 | 05:31 PM
Fish's Avatar
5 from the flat end, top.
Edit.2100 RPM when warmed and on the road for a bit. I don't want to mess with the idle every time it warms up. Turning the idle down solves nothing, I've tried that, it only sets the idle so low that the bike is a HUGE pain to start because of the lack of fuel.
Thanks for the help
Fish
Old Mar 31, 2010 | 05:45 PM
So even with the bike choked it won't start when the idle is down where it should be?
Sounds like your choke cable might be unhooked.
Old Mar 31, 2010 | 07:01 PM
Fish's Avatar
Choke hooked up, slides freely and feels seated when fully pushed in. Both Nylon/plastic nuts tight at carbs.
Old Apr 1, 2010 | 08:03 AM
BeerHunter's Avatar
Slacker
Assuming that the valve clearances are within specs AND the carbs have been synchronized properly, then I would think the idle mixture screws need to be adjusted as Cliby has mentioned already. Be aware that a proper synch cannot be done with valves that are too loose or too tight, and the mixture screws cannot be properly tuned unless the carbs are idling in synch.
That being said, with the right tool, mixture screws can be easily adjusted with the engine running. It would not be a mistake to try that first since it is easy to do and can be redone later if other adjustments are needed as well.
Old Apr 1, 2010 | 08:22 AM
cliby's Avatar
Fish did you do that yet? short of an air leak its probably the most common cause and with a 'little' fiddling you can adjust them on the bike if you have a right angle tool - a shop might let you borrow theirs also if you have a good relationhsip with them.
Old Apr 1, 2010 | 06:34 PM
Fish's Avatar
Not yet but do have the tool and the air mix needles are slotted, got u'm when I was in England. I have a long weekend and hope to get sometime to play with it. Thanks for the help....I'll post results.
Fish
Old Apr 2, 2010 | 05:50 AM
gboezio's Avatar
I would check those valves clearances, rich mix should slow idle while heating up.
A warm air leak at the carb boots would cause this kind of problem, sometimes it's related to the idle pushed too far exposing the pilot holes and getting it dripping changing the mixture, combine this with an air leak and it can cause unexpected behavior.
thedeatons
Jun 21, 2015 09:11 PM
FL02SupaHawk996
May 28, 2010 07:21 AM
Grizz
Jun 20, 2009 05:39 AM
Slim
Aug 18, 2008 09:10 PM
DaxMiddler
Apr 28, 2006 03:22 AM
