idle drop procedure
Old Mar 4, 2012 | 05:13 PM
toeknee19's Avatar
toeknee19 is on a distinguished road
idle drop procedure
I cleaned the carbs and ready to synch, does anybody have a write up on how to do an idle drop procedure? I can't remember its been too long. also, should i check TPS or do they rare jump out of spec.
Old Mar 4, 2012 | 05:37 PM
By idle drop do you mean fuel screw adjustment?
AFAIK, the tps has been discussed but it has been inconclusive as to whether it causes any significant changes. Of the write ups I read even out of spec tps don't seem to make a big diff even when corrected. YMMV
Old Mar 4, 2012 | 05:45 PM
jay956's Avatar
many threads on both topics.
Old Mar 4, 2012 | 05:47 PM
toeknee19's Avatar
yes , fuel screw adjustment, i remember using a tach to adjust the rpm
Old Mar 4, 2012 | 05:54 PM
thetophatflash's Avatar
The procedure is in the manual. Page 5-21.
Old Mar 4, 2012 | 06:53 PM
I like running a little richer than that....so does the bike. Try 2.0 - 2.25 turns out depending on your mods and elevation. Not to mention the adjuster tool is impossible to find and outrageously expensive at about $125.
Old Mar 4, 2012 | 07:14 PM
TPS won't really go out of spec unless you change your idle significantly from what I understand.
Old Mar 4, 2012 | 07:50 PM
spladle160's Avatar
7Moore7 have you checked your tps? most seem to be up around 800 ohms, mine was at 810 and it does make a difference on the bottom end both at idle and pulling away.
Old Mar 10, 2012 | 07:11 AM
Well it comes very high like that from the factory (I think for to emissions reasons). I should have worded that better. What I meant is that once you reset your TPS to 500 ohms, it won't go out of spec very far. My was well above 800ohms to start with as well.
They set it to fit whatever regulation they need to pass and then lock it down. If you notice, you're not supposed to tamper with it (you have to drill out the anchors).
I didn't read the OP very closely. I thought he was asking if he should regularly check TPS!
Old Mar 10, 2012 | 11:29 AM
toeknee19's Avatar
cool thanks guy
Old Mar 10, 2012 | 11:54 AM
I got this tool for the job which really saves alot of work and money
Amazon.com: BikeMaster Extra Reach Adjustment Screwdriver 18-JVE4306: Automotive
27 clams & it works
thedeatons
Jun 21, 2015 09:11 PM
jeephawk
Feb 13, 2012 03:55 PM
tomzxt
May 27, 2011 03:54 PM
supermarto
Dec 13, 2007 09:55 PM
DaxMiddler
Apr 28, 2006 03:22 AM
