I messed up now my bike won't idle
Old Nov 14, 2008 | 04:47 PM
superbawk's Avatar
superbawk is on a distinguished road
I’ve got a 99 SH box stock. I got married and started a family and before I knew it, my battery was dead and the carbs were dry. The bike then sat for 1.5 years. So I finally got off of my but and installed a new battery and fresh gas and the carbs puked gas (stuck floats). So I pulled the carbs disassembled them and cleaned everything I could. I didn’t remove the pilot screws because I didn’t have the tool and I didn’t do my home work. Well the bike won’t run without the choke fully pulled out and it won’t stay running below 2500-3000 RPM.
Before I pull the carbs (again) to remove the pilot screws is there anything else I should do or check while I have it apart. Thanks in advance for any advice.
One good thing has come of this - I found this forum….
Old Nov 14, 2008 | 04:59 PM
hawxter996's Avatar
ole dirty bastard
buy one of those gallon buckets of carb-parts cleaner and let them soak in it overnight
spray inside and out with carb spray and should be good to go.
Old Nov 14, 2008 | 05:26 PM
jbaxx's Avatar
Honducati
Better yet, Get some good fuel system cleaner and put it in the tank and ride around. Fixed the sheet outta mine in about 2 tanks and did NOT have to pull the carbs. It works!!
Old Nov 14, 2008 | 07:15 PM
Only running with the choke on is a classic symptom of a clogged pilot circuit, you need to clean it better. Ream it out with a bristle from a wire brush, spray through with carb cleaner then blow it out with compressed air. You need to hold the pilot jet up to a light and see a solid circle through it.
thedeatons
Jun 21, 2015 09:11 PM
The Last Gunfighter
May 18, 2014 06:48 PM
steve29
Apr 19, 2010 07:14 PM
CentralCoaster
Jan 13, 2010 07:30 AM
DaxMiddler
Apr 28, 2006 03:22 AM
