How pair system works precisely ?
Old 08-05-2005, 04:53 AM
roadrun_fr's Avatar
roadrun_fr
Looking at the service manual, I was surprised !
I was thinking pair system works when deccelerating and that's why we here exhaust popping at deceleration...
But "the pair control valve cuts off supply of fresh air during engine deceleration, thereby preventing afterburn in the exhaust system" as the service manual says.
looking one time more at the service manual, the pair system is flowing fresh air almost all the time, it cuts only at deceleration (high intake vacuum) to eliminate afterburns.
Then, here are some questions :
- Why is there a popping effect at deceleration with pair system enable ? Maybe, the hoses connected to headers have enough fresh air to deliver during a little time and cause afterburns ? or pair valve is not very quick ?
Or it is because of downshifting that leaves the engine to take revs ?
- What are the effects on a dyno gaz analysis with a pair system enabled ? The carburation may always seems to be "lean", isn't it ?
Anyway, I think I will disable this pair system this week end ! and redo a carbs sync by the way
roadrun_fr is offline
Old 08-05-2005, 01:12 PM
also be aware that honda techs did tune this bike to run WITH the pair system. it does greatly reduce emissions, i can tell you that for sure. the only way i can see it robbing power is if you have a claifornia model....
inderocker is offline
Old 08-06-2005, 05:49 AM
roadrun_fr's Avatar
roadrun_fr
Re: How pair system works precisely ?
pair system disabled :wink:
andrewlc77
10-02-2006 12:41 AM
SillyHawk
09-18-2006 10:54 PM
EngineNoO9
09-11-2006 07:23 PM
EngineNoO9
12-22-2005 01:06 PM
Quick Reply: How pair system works precisely ?
