Hesitation during acceleration
Old Mar 10, 2007 | 10:16 AM
FullFlavorPike's Avatar
FullFlavorPike is on a distinguished road
I get a lot of hesitation when I turn the go-stick on my '05. It almost sounds like the bike is hiccuping. Very strange. It's worst when it's cold out, too. If I leave the choke wide-open it won't really do it. Even after the bike crests 150 degrees or so, though, I close the choke and it hesitates on me. Anybody encounter anything like this before??
Old Mar 10, 2007 | 11:48 AM
superbling's Avatar
Sounds like a fuel metering problem. Bike been sitting over the winter?
Old Mar 10, 2007 | 02:22 PM
You're running too lean. You need to rejet the carbs.
Old Mar 10, 2007 | 03:27 PM
Think a dynojet kit is the answer? I run two bro.'s pipes, maybe that has something to do with it?
How much am I going to suffer re-jetting?
Old Mar 10, 2007 | 03:35 PM
superbling's Avatar
Is it happening in the 2500-3500rpm range as you try to roll it on?
Old Mar 10, 2007 | 05:25 PM
Probably about there and above. bike hasn't been sitting though - started doing it when it got cold in the fall and I just figured it was from the chill. But it doesn't like to stop when the bike warms up.
Old Mar 10, 2007 | 05:55 PM
jamesvtr's Avatar
jamesvtr is on a distinguished road
your going to have to do some jetting like what was stated before it will be well worth it
Old Mar 10, 2007 | 08:34 PM
SuperHawkins's Avatar
Yep its a jetting problem....Im running stock jets with a drop-in and slipons and no intake snorkel so I have it pretty bad....waiting on a kit to turn up cheap on ebay
Old Mar 10, 2007 | 08:42 PM
jamesvtr's Avatar
you should put your snokel back on you loose power from removing it
Old Mar 10, 2007 | 08:47 PM
But I love the intake sound too much! I'm not worried much about 1 or 2 hp...I cant utilize it anyways. Give me a car, thats a different story, but a bike....I'll admit my inadequacies
Old Mar 11, 2007 | 03:41 AM
Speed_Demon's Avatar
So it just started doing it all the sudden? If it isn't gummed up carbs you probably have unseated carbs. I got my bike after it sat in police impound for two years (previous owner died on it) and the carbs popped loose during the first start up. This creates a lean condition and gets worse with throttle (engine vibration). I've seen it on every hawk I've worked on. Lean conditions do cause backfires but stock hawk jetting should handle bolt on aftermarket parts without backfiring even at sea level not to say you shouldn't go richer with mods.
Old Mar 11, 2007 | 10:27 AM
Cold air is more dense, thus more air in the air-fuel ratio equation. This will make the bike more lean in the winter, as you describe. The choke experiment solidifies my belief that you're lean. I'm a fan of the Factory jet kit.
NZSpokes
May 17, 2014 12:15 PM
meanhawk98
Feb 13, 2012 11:27 AM
geekonamotorcycle
Mar 23, 2011 02:26 PM
SS_Will
Oct 14, 2008 11:14 AM
david.k1200
Jun 8, 2008 01:13 PM
