help please
Old Sep 4, 2006 | 09:35 AM
andrewlc77's Avatar
andrewlc77 is on a distinguished road
help please
if i wot through the gears it is fine but when cruising at about 2000 to 3800 i get a clunk spit pfft. is this a sync issue?
Old Sep 5, 2006 | 06:01 AM
hawxter996's Avatar
ole dirty bastard
try shimming your carb needles.
i used a dynojet kit and cured all my driveability problems using stock air filter of course.
Old Sep 5, 2006 | 07:39 PM
omniouslink's Avatar
omniouslink is on a distinguished road
can you give a little more detailed description?
Old Sep 5, 2006 | 08:54 PM
andrewlc77's Avatar
whenever cruising at a constant rpm i get backfires through the carbs....i think mainly the front one
Old Sep 5, 2006 | 10:31 PM
First off try your spark plugs. Replace them with some good ones like NGK or better. DO NOT USE AUTOLIGHTS (damn advanced auto people). Do you have any Jet work or exahust work done? if so that could be the issue. Are you sure its only the front? This could be your coils fading out or your CDI acting up. How many miles are on your bike? Have you had other related problems? and also have you or anyone else worked on the bike recently? Did this problem just pop out of no where or did it start really slow?
Old Sep 5, 2006 | 10:34 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
are your carbs jetted or not...i had the same problem by having an aftermarket pipe and NOT jetting them. went through that **** for a few months then jetted...NICE!
Old Sep 6, 2006 | 05:05 PM
andrewlc77's Avatar
ya i just put the jardine rt-1 aluminum high mounts on so maybe that is the case....thanks
Old Sep 6, 2006 | 11:32 PM
Mixture screws to 2 turns out. 1 size up on mains. Shim needles 0.040-0.060". This is a poor man's jet kit for the VTR. Otherwise buy the Factory kit and use my settings on my site as a baseline, except one size smaller mains than what I have because I have the K&N.
Oh, and don't forget the carb sync!!!!
Old Sep 8, 2006 | 06:18 PM
andrewlc77's Avatar
ok i took off the tank and there are no screws in the airbox cover...could this be my problem???
Old Sep 8, 2006 | 08:14 PM
I doubt that seriously. the tank shoud hold the cover down for the most part. But hey try it who knows. put some screws in it and take it around the block! If it dosent fix it you havent lost anything.
Old Sep 8, 2006 | 08:27 PM
hawxter996's Avatar
ole dirty bastard
it could very well cause problems. with the intake pulses causing it to flutter around and breaking airbox seal letting in unfiltered air.
mcadena89
Jun 3, 2009 12:04 AM
mattvdsande
Mar 16, 2009 11:12 AM
FordsnRebels
May 3, 2007 07:10 AM
Speed_Demon
Apr 3, 2007 05:25 PM
scottiemann
Mar 3, 2007 07:48 AM
