Help , Front sprocket
Old 05-01-2008, 10:53 PM
whytey's Avatar
whytey is on a distinguished road
Just put a 15 th on my bike down from a 16 th and tightened it up and it starts banging and making all sorts of shitty noises . the bottom of the chain sort of rises and falls so i loosened it off again and moved it a tooth on the bottom off the rear sprocket but to no avail .
the chain and sprockets are in really good nick by the way .
Any ideas ?
whytey is offline
Old 05-01-2008, 11:41 PM
Death Cattle's Avatar
considering my limited knowledge on it all, all i can suggest is to take it apart and put it all back on again, double checking everything. i would definitely get a second opinion first though.
Death Cattle is offline
Old 05-02-2008, 12:33 AM
Are you saying that when you rotate the rear wheel the chain will tighten and loosen?
inderocker is offline
Old 05-02-2008, 12:51 AM
whytey's Avatar
sprocket
No it does,nt seem to loosen or tighten the rears nice and straight . I jues went and put the old one back on and it done the same just a little less . could it be that ive got it up on the stand and nothing to put load on the chain ?
whytey is offline
Old 05-02-2008, 03:47 AM
FTMS's Avatar
A couple of things, sprockets have a certain amount of run out to them, which is why the chain will go from losse to tight with out changing anything. Adjust you chain at the tighest piont.
Mark the cahin with a marker and see if the noise happens at the same spot each time. If so see if you can find the actual spot, and check the chain rollers in that spot. You might have a couple of broken ones.
Good luck
FTMS is offline
Old 05-02-2008, 06:06 AM
OUCH... MY A$$ HURTS!!!
joshuatest's Avatar
yes, this sounds like you need to tighten your chain... if you went from a 16T to a 15T, the sprocket is smaller, which gives you crazy slack... Your manual gives good instructions on chain tentioning
joshuatest is offline
Old 05-02-2008, 10:28 PM
whytey's Avatar
sprocket noise
Got it sorted , ie dont do the adjustment on the paddock stand . make sure the rear is on the deck and everything comes up trumps . also very pleased as it goes like a rocket . Came whipping down the road 140 km and coming towards me was the local law enforcement looking rather irate so quickly opened it up , shot round the corner and down the road to home , straight into the garage and shut the door . No more riding today but still smiling .
whytey is offline
Old 05-03-2008, 04:08 AM
drew_c14's Avatar
Just out of curiosity, what kind of cars do the police drive in NZ?
drew_c14 is offline
Old 05-03-2008, 02:30 PM
whytey's Avatar
Holden Commodores mostly , look a bit the same as my avatar but not as souped up .
whytey is offline
Old 05-04-2008, 09:35 AM
Is it similar to the Monaro, but smaller?
Hawkrider is offline
Old 05-04-2008, 01:16 PM
whytey's Avatar
Yep , pretty much so but its a four door , probably to throw errant bikers in maybe .
whytey is offline
Old 06-04-2008, 12:56 AM
BLAKCK HAWK's Avatar
BLAKCK HAWK
so, you made the adjustment on the deck [ground] and not the stands ?
and could you send me the link me to the replacement of the chain and sprockets, or how did u do yours ?
did u remove that clutch piston or what ? thanks.
BLAKCK HAWK is offline
mattvdsande
03-16-2009 11:12 AM
duran
08-27-2007 07:57 AM
BLAKCK HAWK
01-27-2007 06:57 AM
98VTR
09-15-2006 05:01 AM
vtwinhooligan
03-06-2006 06:42 AM
Quick Reply: Help , Front sprocket
