Help with factory pro jet kit
Old Aug 4, 2018 | 12:43 PM
PoorMansDucati's Avatar
PoorMansDucati is on a distinguished road
Help with factory pro jet kit(SOLVED)
Hey guys. I got a factory pro jet kit, the #1.7 RK-RaceKit, to be exact.
The instructions dictate I drill the main air jets.
I just need to be sure I get this right, so I need a pic of exactly what to do. To complicate things, I also have a flo-commander. I know to drill the front and back to the different, supplied sizes, but I need specifics.
Really appreciate the help guys!!
Old Aug 4, 2018 | 07:59 PM
you either have to choose between the FP kit or the Flo-Commander, or do like I did and get some custom adapters made that allow you to mate the threaded section from the jet (which FP has you screw into the hole you drill and tap) with the upper portion capable of accommodating the F-C lines.
Old Aug 4, 2018 | 09:36 PM
I'm not sure what hole I have to drill and tap? Is it beneath the fitting Flo commander has you press fit in then? The drill bits in the kit are so tiny, I didn't see a tap in the kit either.
Old Aug 5, 2018 | 04:37 AM
The work on mine was done directly by FP when they installed the HDJ needle jets. In thinking about it further, the small drill bits are meant to enlarge the hole in the main air jets (yes, the one you put the F-C fitting on). So, disregard my prior message and drill away!
Old Aug 5, 2018 | 08:30 AM
The holes on the FC fitting are so large though!
Marc told me he put on his site "carb machining required" to scare people away so they don't drill into the main carb body on their carbs. Lol!
Is it for the holes in the emulsion tubes perhaps?
Old Aug 5, 2018 | 11:18 AM
the place you installed the F-C fittings is the main air jet. I believe the hole in them stock is 1 mm in diameter. IIRC, FP wants you to increase one to 1.1 mm and the other to 1.4mm (110 and 140 jet sizes), hence them supplying the two drills bits in the kit. Emulsion tubes have nothing to do with it.
Old Aug 5, 2018 | 11:31 AM
what is your needle clip positions?
Old Aug 5, 2018 | 01:37 PM
I am using HRC needles, on top of a plethora of other changes, both to the airbox and engine.
Old Aug 5, 2018 | 04:01 PM
Lol! I know about a majority of your changes. You're a legend(a term I do not throw around) on the forum. I've been scouring this site daily for a number of years. I should have known better than to use your bike as a ballpark setting....because it's out if the park! Lol!
For me, this is a little like a guitar legend giving you playing tips. Lol! I really appreciate the help though brother.
Thanks
Old Aug 5, 2018 | 08:16 PM
thanks for the kind words and best of luck with your project
rich.m
Jul 16, 2011 11:16 PM
zmaniv
Mar 2, 2010 10:49 AM
uchi
Nov 29, 2009 04:50 PM
Slim
Nov 22, 2007 05:13 PM
pickle.of.doom
Nov 10, 2004 07:38 PM
