Help with Air Filter Lower Housing
I got rid of all that stuff (from the inside); vent lines run to a common point and bleed off out of a cone filter (via a Krankvent). As for the vents feeding the carbs, put cone filters on and off you go. More internal volume and nothing to mess up airflow close to the stacks
