Help with Air Filter Lower Housing
http://i1043.photobucket.com/albums/...psjouolrxe.jpg
Has anyone lowered the hoses and bottle in the air filter housing ? would like to get the hose away from the velocity stack , have looked at it a few times and I seem to remember someone on here did I it |
I got rid of all that stuff (from the inside); vent lines run to a common point and bleed off out of a cone filter (via a Krankvent). As for the vents feeding the carbs, put cone filters on and off you go. More internal volume and nothing to mess up airflow close to the stacks
Thanks for that Mikstr.
