Hard Shift into 2nd
Old May 8, 2007 | 08:40 AM
DocPigskin17's Avatar
DocPigskin17 is on a distinguished road
Hard Shift into 2nd
My 98 SH sometimes has a hard shift into from 1st to 2nd gear. If I lay on the throttle hard in 1st in is hard to get into 2nd (wants to shift into neutral). I am going to change the clutch fluid today but if that doesn't do the job, any suggestions as to what to do next?
Old May 8, 2007 | 08:47 AM
I think all VTR's are notchy shifters between 1st and 2nd
Old May 8, 2007 | 09:30 AM
Zedicus's Avatar
Zedicus is on a distinguished road
clutch fluid??
theres a shift kit thas spose to help.
theres heim joint kits for the shift rod.
some peeple hav luck moving the shifter up a notch.
Old May 8, 2007 | 11:28 AM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
Originally Posted by Zedicus
clutch fluid??
It's a Hydraulic actuated clutch...remember
Old May 8, 2007 | 12:17 PM
RickB's Avatar
I have the factory pro shift kit in my SH and it did help the 1-2 shift. I have the cheaper $80 version not the evo shift star, just a rod with a ball bearing roller and a spring.
Old May 8, 2007 | 05:11 PM
The Hawk Guy's Avatar
The Hawk Guy
I think this is a very common problem on the superhawks. I noticed the difficulty of shifting into 2nd the first day I rode it (the bike was nearly brand new). Try to find the sweet spot and shift at the right RPM.
Old May 8, 2007 | 05:37 PM
Change the oil to something good (if not already done) and short shift the 1-2 gear change. It shifts smoother at lower rpm. After that shift higher if you like.
Old May 8, 2007 | 07:46 PM
flyin_hawk's Avatar
Long Member
flyin_hawk is on a distinguished road
Pre-loading the shifter helps a lot.
Old May 9, 2007 | 04:25 AM
shayne's Avatar
Don't put up with it, do the mods. That is my opinion.
The Factory Pro kit is worth a fair bit, but it is a very significant upgrade to the quality of the OEM components.
Moving your linkage to change the shift throw is free and easy to do.
The heim joint mod is my own as far as I know, and works well. Not sure how many other people have done it since I mentioned it, but I think there have been a couple. Isn't too hard to do, and the parts are cheap enough. Don't underestimate the effect that quality, well lubricated joints, will have on the shift.
Old May 9, 2007 | 06:59 PM
midijunky's Avatar
midijunky is on a distinguished road
+1, I had shifting issues that I thought were gearbox issues. I changed oil to a known "good" shifting oil, did the heim mod and the spline mod, shifts better now. Still doesn't enjoy shifting into 2nd when you're Really into it, but it's not as bad now.
VTR
May 29, 2014 03:31 PM
ImitationCrab
Nov 20, 2009 03:26 AM
MXC
Jun 18, 2006 05:16 PM
The Hawk Guy
May 2, 2006 04:55 PM
ZZRsouth
Mar 8, 2006 08:24 AM
