1st-2nd Gear Shift Issue/Neutral Pop
Old May 31, 2013 | 11:44 AM
VTR's Avatar
VTR
VTR is on a distinguished road
Hey guys - I'm new to the forum and just purchased a '00 Super Hawk with 24500 miles. Wonderful riding and sounding machine, love it. I replaced the oil and filter (genuine Honda) and took it out for a ride. I noticed the 1-2 up-shift is noticeably harder/rougher than any other up-shift. If I rev out 1st gear and shift it usually engages 2nd gear just fine. However, about 10% of the time it will engage 2nd gear, then within a second later will pop into neutral, causing huge revs under power.
I'm an experienced rider, this is my 18th motorcycle and my 3rd sport bike. I've never had this problem on any previous bike. I've tried changing my shifting technique with no improvement.
I've read on this forum that this may be from bent shift fork(s). I've also read that removal of the engine is not necessary to replace the shift forks. Is this true? I've done quite a bit of wrenching and am prepared to replace the shift forks if necessary, but want to avoid removing the engine and splitting the cases if possible. Your comments and advice is appreciated.
Old May 31, 2013 | 12:47 PM
KCCO's Avatar
What oil did you replace the old fluids with? I have read on here that the SH requires the proper oil more than other bikes, like I said not from personal experience I went over the top on my oil changes and use repsol. This may be something for you to explore further.
Old May 31, 2013 | 12:55 PM
VTR's Avatar
VTR
I used Honda GN4 10W-40 as recommended in the service manual.
Old May 31, 2013 | 02:00 PM
matt365's Avatar
As you've already stated, I'd suspect shift forks are worn. Check the knowledge base for the downloadable .pdf shop manual. I've never had to swap the shift forks on my hawk, so no first hand experience on my part either.
Old May 31, 2013 | 02:22 PM
hmmm, I've only had one VTR engine apart.. so far from an expert on this motor....But I can not visualize replacing the shift forks without splitting the cases.. and the service manual directs the same...
There might be a way of course...but not that I can think of......
OP, if you have a link to the post, thread, write up that says it can be done.. that might help others weigh in on the feasibility...
That said.. the 1-2 shift is the hardest, most likely to result in some gear clacking of all others on this bike. It's not a smooth transmission.. IMHO... the Aftermarket Factory Pro shifter kits help.. but even then.. it's not GREAT, but it does get better.
Might try a different oil as well, just for testing.. I know I can tell by the way it shifts when I need to check my milage and need for an oil change... Try a full synthetic oil .. lots to choose from..
Old May 31, 2013 | 02:28 PM
I have replaced the shift forks... I'd say doing it without splitting it is highly unlikely... And even if you manage, it's probably easier and faster to split the engine anyways...
Old May 31, 2013 | 03:20 PM
Letsrideinsc's Avatar
Letsrideinsc
I totally understand you, and understand that your more experienced than most...do you do this: I learned from a pro racer type guy to keep the pressure on the shifter until you let the clutch out, the gear may slide in when the clutch begins to engage. Just a thought. Maybe the previous owner did a lot of clutchless shifting?
One thing I read about when I purchased mine in 99 was the 1st and second gear clunk, and how our bikes don't like to take off the line, there's that clutch chatter that other bikes don't exhibit.
Old Jun 3, 2013 | 08:25 PM
VTR's Avatar
VTR
Thanks for all of your opinions and advice. I'll try that clutch technique and after a few more miles I am going to change the oil out for a synthetic. I'll keep all of you posted.
Old Jun 9, 2013 | 06:23 AM
jerryh's Avatar
Another thing that helps, and this has applied to every bike I've owned (hydro or cable actuated), is give the clutch lever a strong extra quick squeeze. Also keep an eye on what rpm it likes to shift at and stay with that.
Old Jun 9, 2013 | 06:54 AM
cybercarl's Avatar
You could try moving the gear selector around one spline clockwise which will give you a shorter shift.
Old May 15, 2014 | 02:34 PM
thielb's Avatar
thielb is on a distinguished road
I'm having the same issue right now on my 2000 with 30k miles. Going from 1st to 2nd is becoming a bigger and bigger pain in the *ss quite rapidly. It seems to get worse when the bike warms up. Most of the time it just wont even go to 2nd gear, its not that its slipping out of gear once it gets in. At least half of the time the 1st to second just results in a nasty chatter sound and neutral. Need to do some more city riding where I'll need that shift more but my last trip was really frustrating at every stop. Oil will be changed sometime in the next couple of weeks but it feels way to stubborn to just be that...
Old May 15, 2014 | 03:49 PM
thetophatflash's Avatar
When did you last bleed the clutch system?
Old May 15, 2014 | 03:59 PM
TboneNast's Avatar
Amateur Hour, Every Hour
TboneNast is on a distinguished road
I put in Mobil 1 10W-40 4t and it definitely helped, but it is still a beastly toe-up to 2nd. For me it's worse the higher RPM and I've started to shift from 1st to 2nd around 3600 RPM while keeping throttle rock solid (don't let off at all when you pull clutch).
What he said I drained & bled the clutch with new Lucas DOT 4 and there was an improvement, not major, but the lever feels smoother and the shifts are a touch gentler.
Old May 15, 2014 | 04:17 PM
thielb's Avatar
I've only had the bike for a month so that's something I have yet to do, not sure if the PO had done anything like that. I'll probably do that all in one go then, oil and clutch. Might need to fidget with the aftermarket rearset too a bit, feels sloppy and pulls pretty far down to 1 and all the ups as well...
Thanks for the quick replies fellas
Old May 15, 2014 | 04:28 PM
TboneNast's Avatar
P.S. When you drain clutch res all the way and refill, make sure to slowly pump-prime the clutch lever at least 10 times before opening the bleed valve even if you have a bleeder gun/kit. Also, on my bike the clutch bleeder needed to be opened a full half turn before it was effective. Don't just crack it.
P.P.S. Go Pack Go!
Old May 28, 2014 | 06:05 PM
Appletonhawk's Avatar
Appletonhawk is on a distinguished road
Thielb the rear sets prob do need some adjusting yet to get your gear shifts smoothed out. Like I told you I installed those over winter and only got to ride it about 30 miles before selling it so I know they need some fine tuning as is expected with those rear sets.
Old May 28, 2014 | 09:20 PM
thedeatons's Avatar
The heim joint mod helps with this. Mine now feels like it has the precision of an indy car...
James
Old May 29, 2014 | 03:31 PM
By the way thielb now that it's nice out I want my bike back! Haha
Hayai
Dec 11, 2011 05:23 PM
six6nine9wpk
May 13, 2011 11:10 PM
df34
Jun 21, 2008 08:27 AM
ClevelandSuperhawkRumble
Mar 13, 2005 03:09 PM
MikeD
Mar 8, 2005 10:34 AM
