hard rain=poor performance, studder, stall
Old May 24, 2007 | 04:31 PM
iamanonymous's Avatar
iamanonymous is on a distinguished road
so basically when it rains, the bike hates it. anyone else have this problem? i thought it was because i modded the airbox, but i bought a new one. im thinking wet coils, battery, etc. ideas?
Old May 24, 2007 | 07:13 PM
superbling's Avatar
There is a tank vent tube that leads down to the ground on the front left side of the bike. It can pick up water while riding in the rain which creates vapor lock in the tank. Tank vapor lock will not let gas flow from the petcock properly, thus the poor running.
Another cause is water getting past the front spark plug cover and creating a misfire.
Old May 24, 2007 | 09:46 PM
also check if side stand switch is shorting out. remove, grease & reinstall
Old May 24, 2007 | 09:58 PM
Yeah, what they said.
Old May 25, 2007 | 10:27 AM
honestly i feel it may be the number two answer
Old May 25, 2007 | 11:42 AM
RickB's Avatar
You can use some dielectric grease in the plug boots to help keep moisture out...
Old May 25, 2007 | 12:36 PM
DocPigskin17's Avatar
DocPigskin17 is on a distinguished road
Same problem. I have been stuck on the side of the road more than once in a downpour. I may have better luck rubbing the dielectric grease on my skin as a water repellant instead.
Old May 26, 2007 | 07:40 AM
thats funny. where do u put the grease? just on the contact for the plug or what?
Old May 26, 2007 | 07:50 AM
On the sidestand switch...
Remove the bolt retaining the switch that is on the side stand itself, clean and pack the backside of the switch (there is a "tang" in a recessed cavity that engages the sidestand), and pack the cavity with waterproof (not dielectric) grease; reassemble.
Old Jul 11, 2007 | 11:29 AM
westcoast's Avatar
westcoast is on a distinguished road
I sealed all the connectors including the ignition switch with some electrical grade RTV 4 yrs ago after the same happened to me in the rain. Haven't had that problem since. By the way, dielectric grease only prvents corrosion.
Old Jul 11, 2007 | 11:30 AM
westcoast's Avatar
And as for the side stand switch, cut the wires and tie them together. Who needs that lame switch anyway.
smokinjoe73
Dec 1, 2013 03:18 PM
ima98chickenhawk
Jul 3, 2010 02:54 PM
dirt899
Apr 29, 2009 06:53 AM
zixxer
Mar 15, 2009 05:07 PM
2005Hawk2006
Sep 14, 2006 11:59 PM
